Home > Off Topic - Other Cars > Vibration when braking from 60MPH in a Renault Twingo
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
As a local runaround/spare car we have a 2014 Renault Twingo Mk3. At it's last service it had a new O/S coil spring and tyre. When we got it back there was a vibration when braking at 60MPH similar to what I would expect with a warped disc but quite subtle. I have since changed the discs and pads and noticed while doing these that the O/S shock was leaking quite badly and the dust cover was split in several areas. Why the Renault garage didn't mention this is beyond me, especially as they had the shock off to change the spring. So I have now changed both front shocks and fitted new dust covers. When braking though from 60MPH I still have the vibration, taking a bit more notice this time I realised that the vibration isn't felt through the steering wheel, more through the floor. Is it possible that the new tyre could cause this. I have checked and can see the red dot is opposite the tyre valve so would appear to me at least that it has been fitted properly. There are no bulges obvious on either side of the tyre. I have had a tyre in the past sound like a worn wheel bearing but not experienced vibration from one, especially a new one. I should mention that at lower speeds (30, 40) there is no vibration and no vibration at speeds above these until the brakes are applied. 2011 TDV8 Vogue SE
Post #563430 3rd Aug 2020 8:01am
Weegie
Possibly a sticking caliper? John
GAP iiD BT
Post #563432 3rd Aug 2020 8:31am
Baltic Blue
Swap the wheels around, diagonally?
See if it helps .
Post #563433 3rd Aug 2020 8:38am
dennij
Thanks for the replies.
Calipers are fine, neither are sticking.
Cannot swap tyres front to rear as they are different sizes 165 front 185 rear 2011 TDV8 Vogue SE
Post #563435 3rd Aug 2020 9:12am
Crasher242
Could be lots of things relating to the suspension or steering. Track-rod arms and bushes would be my next port of call if you are happy to have discounted the discs/pads from being the culprit.
If you have access to a ramp or pit, would be worth getting underneath with a pry-bar and doing the old 'Ed China' bit by testing for play in anything at the front. Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #563468 3rd Aug 2020 3:02pm
dennij
I wish I had access to a ramp, would make my life so much easier and my back would thank me too I suspect.
Good old Edd China, I haven't watched Wheeler Dealers since he left 2011 TDV8 Vogue SE
Post #563528 4th Aug 2020 9:40am
dennij
Gave the Twingo a wash this morning and had a good look round again just to see if I missed anything and I noticed that the Renault dealer have put the wrong size tyre on, so I now have one at 185/60/R15 and a correct tyre at 165/65/R15
Guess this may be why I have this vibration 2011 TDV8 Vogue SE
Post #563917 8th Aug 2020 9:05am
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I would have thought that if you can feel the vibration through the floor and not the steering wheel then your problem may be coming from the rear and not the front 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #563997 9th Aug 2020 7:47am
