![]() | Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I have got the full kit on order and expecting delivery in the next week or so, but I am seriously worried that it is far more involved than I originally thought the fitting would be.
Happily take a second hand, never fitted set if needed Mike |
Watch this space |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
i think what Ian means is that he will come up to you and fit it free of charge... |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Well done Andy - wriggling that fuse board out is probably the hardest part of the install - let me know if you have any questions - by the way make sure you set DIP switches 2,3 and 4 to Down (ON) - the DUAL view instructions mistakenly just say 2 and 3.
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 113 ![]() ![]() ![]() |
Mine is a single screen not a dual, ive got two sets of instructions one says 2/3 the other 2/3/4 !! 2011 4.4 TDV8 2000 4.6 P38 1998 D1 300tdi |
Andy, I’m fairly sure that is your issue! The correct PIN config is 2,3 AND 4 set to on for both single and dual view.
OK then. Its in and it all works !!
i had the no sound issue but it took Steve 5 mins to tell me what to do - you just have to short the Aux wire To ground under the rear console Aux socket - cleaner than a blank jack on the socket. Its not needed on all cars as they dont all have aux detect and I’m sure I mentioned this in one of my earlier posts.
Ha ! 5 mins ?
