Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
ChrisRRV Member Since: 30 Jun 2020 Location: Belfast Posts: 104 |
Many thanks for all the help and advice |
7th Jul 2020 1:22pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Escuse the intrusion, but, although Chris' L322 is 54 plate it is actually a 2005 with the later MOST. It just looks as if you were talking about the earlier setup.
7th Jul 2020 2:06pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Yes you are 100% right but it’s still has ibus - infact all ff flabbergasted I uat right up until 2009 for the sas , clock and steering controls Current stable:
7th Jul 2020 2:29pm |
Have you got it yet? Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
13th Jul 2020 9:34pm |
Any joy? Current stable:
26th Jul 2020 10:45pm |
Not in yet Dan
27th Jul 2020 7:19am |
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 |
7th Sep 2020 8:39pm |
That unit looks the same as mine that I left in the car when I sold it to a breaker last December probably isn’t but I had the same issue with the steering controls never working. Did you get the carplay adapter as mine he that I left in?
8th Sep 2020 7:55am |
Just re read and realised no canbus box that will be your problem - however my work arounds will work I think but you are going to have to lay out £50 Ian for the resler and app - imho it’s worth it as it does a lot Current stable:
8th Sep 2020 7:56am |
Thanks - came from Somerset - not sure if its yours but the guy did also claim it was fully working plug and play, met my first shyster of the RR scene I think. |
8th Sep 2020 11:14pm |
Guvna Member Since: 20 Sep 2020 Location: Stockton Posts: 1 |
Hi mate just want to pick your brains. I may be getting my hands on a 2005 4.2SC with screens in the headrests and I think it has the HK Logik7 but not 100% sure. I want to stick an android HU in it ASAP if I am to bite the bullet and buy it but just wondering with your set up if the steering wheel controls still work? From what I’ve gathered from what’s been said you take ground/power from the cigar lighter, permanent from anywhere with constant live and ibus to communicate with other CAN related stuff. Would the steering wheel controls work though Ibus? |
20th Sep 2020 1:19am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I've got a feeling that you'll find a 2005 SC is the touch screen that uses a different optical connection... I only say that because the 4.2l engine on the SC is a Jaguar unit sourced from Ford.... I you've got a Ford engine you've also got a Ford head unit which is optical not can-bus or i-bus.
20th Sep 2020 6:48am |
So you will need a most adapter from Avon about £100 and a 5m most optical lead. You can pick up bus from the clock we still have bus up until 2009 just a mini version and yes that means steering controls work! You need to buy one designed for the earlier l322 or x5 but must be thin with no CD player I'd go 10.25" I then got a jaguar male to iso adapter and a iso to a female bow adapter plugged them together and tapped the bus wire and plugged it all in Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
22nd Sep 2020 12:43pm |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 16 |
Any chanse you can send me the photos Hayla ds? Dont wanna by a cable, like to do it my self. Struggelig on finding the right wires as I dont have a pin 13 on the radio plug, or it is there, but there isnt any wiring there. |
8th Nov 2020 9:58am |
