Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005...
Page 18 of 20 <123 ... 17 181920>
ChrisRRV
United Kingdom 2004 Range Rover Vogue 4.4 V8 Tonga Green
Many thanks for all the help and advice
Post #560497 7th Jul 2020 1:22pm
Danwilderspin
I have just remembered something....
If yours has the new gear in the old shape is your actual head unit in the boot? If so you will need a 5 m harness from the boot. However if you are sensible you can use wire taps from the front as you don’t need to worry about speakers
Iirc you only need :
Ibus - Tap from the clock.
12v permanent - from fuse box or anywhere really
12v ignition - cigar lighter
Ground - cigar lighter
As there are no lights as it’s so big I’m pretty sure you don’t need illumination
Aside from the ibus you will need these taps anyway for the most interface Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #560499 7th Jul 2020 1:24pm
Weegie
Escuse the intrusion, but, although Chris' L322 is 54 plate it is actually a 2005 with the later MOST. It just looks as if you were talking about the earlier setup.
Apologies if I am wrong. John
GAP iiD BT
Post #560502 7th Jul 2020 2:06pm
Danwilderspin
Yes you are 100% right but it’s still has ibus - infact all ff flabbergasted I uat right up until 2009 for the sas , clock and steering controls Thumbs Up Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #560506 7th Jul 2020 2:29pm
Danwilderspin
Have you got it yet? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #561323 13th Jul 2020 9:34pm
Danwilderspin
Any joy? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #562768 26th Jul 2020 10:45pm
ChrisRRV
Not in yet Dan
I hope to get ot installed in the next week or so
Post #562782 27th Jul 2020 7:19am
Ian G
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
Hi all, got this unit installed yesterday.
My vehicle is 2003 with LCD head unit originally, without DSP but does feature an amp in the boot XQK000020. Did cause me some problems as the amp was not switching on as the remote wire was not present in the Eonon loom.
Bought used so I don't know what loom I have but all connections are in the dash, didn't need to run any wires to the back.
Previous owner also told me the unit was fully functional but I don't have steering wheel controls or illumination either in the buttons or screen brightness.
There is a Steering Wheel app but its just a grid of names like VOL+ NEXT PREV etc. which I can't work out what to do.
I have no CAN box but also can't see where it might plug in either to the car or the unit. Obviously rather not spend any more money if its not necessary.
Post #566552 7th Sep 2020 8:39pm
Danwilderspin
That unit looks the same as mine that I left in the car when I sold it to a breaker last December probably isn’t but I had the same issue with the steering controls never working. Did you get the carplay adapter as mine he that I left in?
If it’s not mine there is obviously an issue and lucky for you there is a fix - unfortunately I don’t remember part one for the illumination I think you just need to bypass the illumination wire directly to the Headunit not into the canbus box do some Googling that’s how I found it.
The second part is to buy ibus app and a resler interface and iirc this gave me steering controls amongst a load of other things including welcome lights Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #566584 8th Sep 2020 7:55am
Danwilderspin
Just re read and realised no canbus box that will be your problem - however my work arounds will work I think but you are going to have to lay out £50 Ian for the resler and app - imho it’s worth it as it does a lot Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #566585 8th Sep 2020 7:56am
Ian G
Thanks - came from Somerset - not sure if its yours but the guy did also claim it was fully working plug and play, met my first shyster of the RR scene I think.
Post #566684 8th Sep 2020 11:14pm
Guvna
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
2005 HK Logik7 android retrofit
Hi mate just want to pick your brains. I may be getting my hands on a 2005 4.2SC with screens in the headrests and I think it has the HK Logik7 but not 100% sure. I want to stick an android HU in it ASAP if I am to bite the bullet and buy it but just wondering with your set up if the steering wheel controls still work? From what I’ve gathered from what’s been said you take ground/power from the cigar lighter, permanent from anywhere with constant live and ibus to communicate with other CAN related stuff. Would the steering wheel controls work though Ibus?
Post #567511 20th Sep 2020 1:19am
miggit
I've got a feeling that you'll find a 2005 SC is the touch screen that uses a different optical connection... I only say that because the 4.2l engine on the SC is a Jaguar unit sourced from Ford.... I you've got a Ford engine you've also got a Ford head unit which is optical not can-bus or i-bus.
If I'm wrong and you do have the BMW non touch screen system, nicked from the E39, then the can-bus wire is the white and grey with yellow rings, the nearest place to pick it up is the redundant CD changer wiring. But if you are using a proper boot extension lead you will connect up to the can-bus in the boot well off the 40 pin connector from the BM54 radio unit... Handy tip, I've just done one for a friend, I cut the wires 1 at a time from the plugs and joined them... when it came to doing the can-bus, illumination and aerial amp the wires in the extension lead were of a different colour to Pete's original menu, so I plugged in the 40 pin extension lead connector to the factory loom and I could see instantly which wires needed to be joined to which!
And lastly it is way easier to run the lead from front to back if you have already removed the plug from the boot end of the loom! Yesterday I couldn't spell Engineer... Today I are one!
Post #567515 20th Sep 2020 6:48am
Danwilderspin
Re: 2005 HK Logik7 android retrofit
So you will need a most adapter from Avon about £100 and a 5m most optical lead.
You can pick up bus from the clock we still have bus up until 2009 just a mini version and yes that means steering controls work!
You need to buy one designed for the earlier l322 or x5 but must be thin with no CD player I'd go 10.25" I then got a jaguar male to iso adapter and a iso to a female bow adapter plugged them together and tapped the bus wire and plugged it all in Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #567719 22nd Sep 2020 12:43pm
Mads
Norway 2004 Range Rover HSE Td6 Bonatti Grey
Any chanse you can send me the photos Hayla ds? Dont wanna by a cable, like to do it my self. Struggelig on finding the right wires as I dont have a pin 13 on the radio plug, or it is there, but there isnt any wiring there.
Post #572154 8th Nov 2020 9:58am
