![]() | Home > Technical (L322) > Iid tool live codes height sensor help please |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
What’s that about? 2018 Suzuki Jimny 2003 written off
No help? 2018 Suzuki Jimny 2003 written off
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8396 ![]() ![]() ![]() |
Usually get a load like that when you get a flat battery...
As above, clear all faults, run it around for a day or so and then re-check. Most of them look like "normal" ones that pop up due to low battery etc. Only way is clear and re-check ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Thanks for the replies
Message Pat at Gap on here and ask him, they will sort you out... |
Cheers
Looks like you need a Front Right height sensor.. |
Yep cheers
Speaker faults are standard on most fatties... does the PCM work? if it does ignore the fault, all the others are probably down to that sensor... Pete
