Home > Technical (L322) > Iid tool live codes height sensor help please
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
As above, I’ve just got my bt iidtool
I have googled quite a bit adaptive dynamics fault and suspension fault, borrowed a friends reader which said front right height sensor, I checked that and all other wires , front right has previous repair (I’ve had the rr four plus years I think) so thought I’d get the iid tool so I could check the sensors voltage and anything else I can with it.
I plugged the tool in earlier with the rr running(I tried it engine off ignition on too), the tool loaded up ok as I’d already set it up (admittedly not updated/plugged into pc, just connected to iPhone X) checked/screen shot/cleared codes,
So I wanted to check live values, went into full list, selected all front r/h height options all stated n/a
Selected a couple of other values which also stated na!
I’ll admit I’m not overly good absorbing what I read having read the gap manual
Sorry if it’s a stupid question
It’s a 3.6 2009 (my10) Cheers 2018 Suzuki Jimny 2003 written off
2016 Range Rover TDV8 MY10 current
2013 Range Rover TD6 2005
2012 Defender TDCI 2007
2010 Toyota Hilux 2003
2009 Audi TT 1.8T 225
2007 Suzuki SJ 413 with 1600 fitted
2006 Yamaha R6 2000 still have this
2006 Audi A3 1.8T 1999
2006 Defender TD5 1998
2005 Audi A3 1.6 1998
2004 Suzuki vitara 1994
2002 Proton 1500tripple valve 1991
Post #559298 27th Jun 2020 9:59pm
DrRob
Shocked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #559300 27th Jun 2020 10:02pm
Jammer600
What’s that about? 2018 Suzuki Jimny 2003 written off
Post #559303 27th Jun 2020 10:17pm
Jammer600
No help? 2018 Suzuki Jimny 2003 written off
Post #559561 29th Jun 2020 10:56pm
Usually get a load like that when you get a flat battery...
Try clearing them, take it for a drive and check them again... Thumbs Up Pete
Post #559562 29th Jun 2020 11:07pm
DrRob
Jammer600 wrote:
What’s that about?
As above, clear all faults, run it around for a day or so and then re-check. Most of them look like "normal" ones that pop up due to low battery etc. Only way is clear and re-check Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #559575 30th Jun 2020 7:58am
Jammer600
Thanks for the replies
The main part I’m struggling with is getting live info out of the iid?
I’ve cleared the codes and it comes up with the height sensor mainly so wanted to check the lives but it just says n/a? 2018 Suzuki Jimny 2003 written off
Post #559576 30th Jun 2020 8:00am
Message Pat at Gap on here and ask him, they will sort you out... Thumbs Up
Try a hard reset first, then clear faults, then a drive then send Pat the faults you have...
https://www.disco3.co.uk/wiki/Hard_Reset
Thumbs Up Pete
Post #559578 30th Jun 2020 8:16am
Jammer600
Cheers
Lives now showing, no voltage showing the other side of the height sensor 👍🏼
Yep all cleared and without even driving and here’s the faults
Post #559698 30th Jun 2020 9:51pm
Looks like you need a Front Right height sensor.. Thumbs Up Pete
Post #559705 30th Jun 2020 10:44pm
Jammer600
Yep cheers
I plugged the iid into the pc earlier and updated it, plugged into the rr and got the lives which hopefully states the obvious
I’ve just ordered a sensor 👍🏼🤞🏼
Unsure about the other bits though 2018 Suzuki Jimny 2003 written off
Post #559706 30th Jun 2020 10:46pm
Speaker faults are standard on most fatties... does the PCM work? if it does ignore the fault, all the others are probably down to that sensor... Pete
Post #559708 30th Jun 2020 10:58pm
