Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod.
Page 9 of 15 <123 ... 8910 ... 131415>
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Yes GGDR agree.
By 2012 LR should have known of the problem with a simple fix if the engine is not installed yet.On the assembly line this is easy to fix.
Not a pretty picture when the top LR product leave smokescreens on motorways....not good for the image Laughing Laughing 2012 TDV8 Vogue SE 4.4
Post #557337 11th Jun 2020 4:29pm
Weegie
With lockdown and little use, have your seals dried out and failed to an extent? John
GAP iiD BT
Post #557339 11th Jun 2020 4:30pm
Frans@Yamorna
I think there is a good possibility that it is the case Sad Sad 2012 TDV8 Vogue SE 4.4
Post #557340 11th Jun 2020 4:44pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
northernmonkeyjones wrote:
I’m pretty sure what the turbo drain mod does is simply give it a path back to the sump.
It does, so why the scavenge pump???
The parts involved....
 BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #557355 11th Jun 2020 7:17pm
Possibly due to positive crankcase pressure, but really, just guessing.
Basically the solution is to drill a hole in the side of the sump/block, and plumb it in. How or why this bodge fix works I don’t know, which is why I never bothered to have it done. Having some YT LR tech drill into my engine wasn’t on the cards.... There is nothing that can't be fixed with a hammer😜😜
Post #557356 11th Jun 2020 7:30pm
GGDR
It's the sump:
If you look on the left you can see the two plugs. Both come out for the job. Top one (when facing right way up) is the new drain entry. The other is used to flush out any scarf then it's replugged.
Dead easy off the car!!!
. Cheers, Greg
Post #557357 11th Jun 2020 7:46pm
Baltic Blue
I started this thread back in 2016.
B.B. was a real bad smoker.
I wasn’t happy about the thought of someone getting out the black and decker to drill my sump, but I couldn’t accept the thought of worrying every year will it fail the MOT smoke test....
4 years later and I have still never seen the remotest hint of smoke since the job was done, and despite my initial worries I have no hesitation in recommending this mod to any owner with a smokey engine.
Post #557361 11th Jun 2020 8:08pm
GraemeS
I don't specifically know why the slow drive allows oil to build-up without the extra, direct to sump drain but it suggests that the turbo's seals have become very weak to the extent that the scavenger pump can't produce a low enough pressure.
The scavenger pump is fitted to both the V6 and V8 versions of the engine because their secondary turbos are mounted lower down than the primary turbos and it was considered that the unassisted drains might not drain properly with the engine on the side-slopes that LR vehicles can otherwise be used. In looking for a solution to the TDV6 identical smoke problem it was easy to re-instate the higher direct drain hole that was used in the twin (cf bi-) turbo 2.7 Jag engines which was still in the 3.0's casting to test if the oil drained sufficiently on the side slopes, which it did. The 4.4's sump didn't continue the 3.6's direct drain attachment facility so the make-shift fix was to drill and tap the old 3.6 drain hole to allow a fitting to be screwed into the sump.
Post #557374 11th Jun 2020 9:05pm
AJGalaxy2012
That makes sense, thank you. BMW i3 Electric Car
Post #557377 11th Jun 2020 9:27pm
GraemeS
Digressing a little, a new early 3.0 RRS here in Oz eventually had the engine replaced under warranty when serious smoke couldn't be stopped by multiple new secondary turbos then a new scavenger pump. It seemed that the oil-way connecting the turbo drain reservoir at the bottom of the sump with the scavenger pump at the top of the back of the right head must have been blocked or severely restricted. This was when LR was replacing lots of turbos, including my D4's, thinking that the turbo's seals had failed rather than the real cause. My D4 was due for another turbo just after the end of warranty but still covered for the earlier fault when the updated drain was released which I then fitted myself, being more convenient for me.
Post #557382 12th Jun 2020 2:51am
Frans@Yamorna
Thanks GraemeS for a very good explanation of this problem.
Will drive the car longer over the weekend to see if the problem is of a more permanent nature. 2012 TDV8 Vogue SE 4.4
Post #557383 12th Jun 2020 5:52am
DrRob
If it continues after multiple "boots" then a drain might be needed.
Unrelated but might be worth noting. My secondary turbo was replaced due to it leaking oil. I never had smoke before or after and I regularly booted it (when warm) before and after new turbo. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557390 12th Jun 2020 7:39am
Frans@Yamorna
Previous week booted it a few times and no smoke :DVisiting gamepark tomorrow,so plenty slow travelling!This will be the test.Will report back!
Regards 2012 TDV8 Vogue SE 4.4
Post #558285 19th Jun 2020 6:31pm
Frans@Yamorna
Ok did do the trip to gamepark.
Happy to report that it does seem that the excessive smoking was due to the long period of standing!Enough time to test with long periods of slow driving.There is a hint of smoke after booting it after a period of slow driving but nothing so bad to justify the cost of eliminating it!!
Really enjoyed using the car again!!What a pleasure to overtake Very Happy Very Happy
Post #558502 21st Jun 2020 5:42pm
AngelsBoy
Czech Republic
GraemeS wrote:
The secondary turbo has its own drain which is emptied using a camshaft-driven scavenger pump. The pump stops as soon as the engine stops yet oil pressure to the turbo and other bearings takes a while to leak out of all the bearings. The turbo oil would normally be sucked out via the drain by the pump but the pump is stopped, blocking oil flow so oil escapes from the turbo's bearings into the inlet side, pooling until cleared when the turbo is used. When the turbo's seals are new they don't allow oil to escape but as the seals aren't designed to hold oil pressure because the drain prevents pressure build-up, as the seals wear a little they will allow oil under pressure to escape when the drain in blocked.
The revised drain has a second pipe going directly into the sump, bypassing the scavenger pump.
Oil flow into a turbo is restricted by the size of the hole in the turbo to maintain oil pressure to the rest of the engine and the turbo's drain provides virtually no flow restriction.
Hi GraemeS,
And when a refurbished turbo is installed, including new seals (absorbs most of the pressure). Where does the excess oil go? To the exhaust? Or can it go through the radiator to the engine ...?
Post #563216 31st Jul 2020 12:31pm
