Home > Maintenance & Mods (L405) > dynamic mirror indicators |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
One other thing. On the part that illuminates are yours Stamped in the plastic “12v 5w” (Where it says DOT SAE etc)? 2014 FF Autobiography 5.0 SC
31st May 2020 9:51pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
The packaging will be Powerfuluk's Stan... They try to keep a standard when being from them... So, those may have arrived in jiffy bags for all we know Stan |
31st May 2020 10:08pm |
I will be speaking to Simon @ Powerfuluk over the next few days Horse... So i will interrogate him for you sir |
31st May 2020 10:10pm |
Haha got a good chuckle from your reply Craig. It does look like different LED modules are being used in mine vs the ones you all got. Yours being more powerful LED. 5w is generally pretty bright for indicators. If we could get 10w that would be something! Oncoming traffic would need 2014 FF Autobiography 5.0 SC
31st May 2020 10:18pm |
Any word guys? Yours definitely say 5w on them?
1st Jun 2020 7:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
says 5w on the box but cant confirm what it says on the light unit as its fitted but i assume it will also say the same... ... - .- -.
2nd Jun 2020 10:30am |
Confirmed with another member on the 5w....you can see it once installed...its by the DOT E yada yada stamp on the lens.
2nd Jun 2020 12:28pm |
i had a look at the OE light and it has a small led at the front and the light is channelled down the perspex to the end ...i thought it had leds all down the light but it seems not.. ... - .- -.
3rd Jun 2020 2:08pm |
Right...OEM are made to shoot the the light (rearward) down the channel So you see the light from the side of the car/coming up along side of it.
3rd Jun 2020 2:41pm |
Well my second go around has hit the shores....let’s hope they don’t sit in NY for 1-2 weeks like everything else that’s imported 2014 FF Autobiography 5.0 SC
8th Jun 2020 4:55pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Fingers crossed you get them ASAP! At least NYC is not too far from you SDV8 AB MY 2019
9th Jun 2020 9:55am |
Hopefully by the weekend...but not keeping my hopes up 2014 FF Autobiography 5.0 SC
9th Jun 2020 1:01pm |
With any luck i should have mine tomorrow 2014 FF Autobiography 5.0 SC
12th Jun 2020 4:16pm |
Got mine today. Did notice the plug is backwards so It won’t snap in... Did any of you use electric tape or anything to hold the plug so it doesn’t disconnect and remove power from the unit? 2014 FF Autobiography 5.0 SC
13th Jun 2020 6:39pm |
