Home > Maintenance & Mods (L405) > dynamic mirror indicators |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35363 |
found these on the powerfuluk site....anyone fitted them?
13th May 2020 5:15pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
They’ve done a recent video on them, not sure to be honest |
13th May 2020 6:04pm |
yes the video is in the link...
13th May 2020 6:23pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7814 |
I don’t get why there should be dynamic anything.
13th May 2020 6:51pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8257 |
I'm with Mark... find them offensive on a lot of cars, especially when the in front sits for 10 mins waiting for the lights to change with his indicator on in a designated turning lane...
13th May 2020 7:42pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
I'm with Mark & Pete - they are silly, distracting & look like they should be on a boy racers car. They simply do not stand out in a distance.
13th May 2020 8:45pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
They stand out more in a distance. Look at the video.
13th May 2020 8:49pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
I was discussing this with Simon from Powerfuluk a week or so ago! Theirs doesn't!!! Direct the light to the rear corner of the light...
13th May 2020 11:04pm |
These have the flat section o the edge which is the section that faces toward the rear of the car to alert cars passing buy. So it should point light back just like OEM as long as the LED goes all the way back/some light is directed back. These flash at the same rate as OEM, any dynamic signal does it’s just that each portion is delayed for a split second from the previous to make it look like it’s moving. If you tape off the entire thing but leave a section an inch or so wide you’ll see it flashes the same rate
13th May 2020 11:16pm |
That was my issue... the last 'important' bit does NOT illuminate at all! |
13th May 2020 11:34pm |
is this what you mean Craig..
14th May 2020 7:50am |
@horse, where did you find them cheaper? ... - .- -.
14th May 2020 7:53am |
That’s it Stan... put your hazard lights on and stand behind your car in an overtaking position and it will become very clear... 👍 |
14th May 2020 7:58am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
Having read that - I'm assuming that this is a modification that would need to be reported to your insurance company.....
14th May 2020 9:15am |
