![]() | Home > Maintenance & Mods (L405) > dynamic mirror indicators |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
dunno Alistair...these are 'E' marked so does that make them ok?
i see what Craig is referring to now....put the hazards on and from the front you cant see much of the light and stood at the back you see a small orange bit right on the tip of the mirror housing..
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
The C & U Regs must have been changed because at one time all indicators had to flash in unison with one another.
any news on yours yet Horse? ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Ive had the same thought as you Brian when i purchased our latest Ford Connect... The front fogs are the cornering lamps! Not twin bulbs as i was expecting... |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
nothing yet 2014 FF Autobiography 5.0 SC
Cagonline Member Since: 20 Dec 2019 Location: Nottinghamshire Posts: 15 ![]() ![]() ![]() |
hi Peter and welcome to the forum..so you think they are worth he cost? are they significantly brighter?
Hello Stan,
thanks Peter..
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Stan, I fitted a pair of these this morning and no, they aren't as visible from the rear, but you're right, they are more visible from other angles. On balance, I'd say they're a good mod and had Craig not mentioned the view from the rear, I doubt I'd have noticed. He does of course have a point though. |
so do you recommend them Rob? ... - .- -.
Yes, on the whole very pleased and they seem well made. Just be aware you need to push the connector in the opposite way to originals for some reason and the mirror casings in my case were a bit of a |
thanks for the tip Rob...
