![]() | Home > Maintenance & Mods (L405) > dynamic mirror indicators |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
just pushed it in..seemed secure . ... - .- -.
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Same. Seems like it should stay. Hopefully 2014 FF Autobiography 5.0 SC
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 ![]() ![]() ![]() |
Just received a set. What's the trick for getting the mirror caps off? Have watched several videos, and they all show prying in a different spot. The service manual shows removing the mirror glass to access the clips? Help? |
as in the powerfuluk video...pry off on the outter top side of the cover..be careful cos they do fly off... ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Nearly into July and still no change Stan... ![]() |
i did say dull winter weather Craig....as you say its nearly July and i'm making an educated guess that this is still summer.. |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
I would definitely recommend using a plastic trim removal tool and follow the instructions as per Stan's recommendation (the powerfuluk video) ![]() SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
What would irk is that they aren’t in time with the front indicators......
That's why I have now brought a new Fullfat |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3256 ![]() ![]() ![]() |
When I did my driving test you had to give hand signals. Initially the only mechanical/light signal which was legal was the semaphore arm type direction indicator.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
AFAIK indicators must flash in unison - unless of course the C & U Regs have been changed to suit the use of sequential indicators & auxiliary lights used singly such as those annoying cornering lights for cars with rubbish headlamps &/or drivers that need a trip to Specsavers. 2003 Range Rover Vogue TD6 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
My L405 has cornering lights - not sure whether you can turn them off, but nothing obvious on the car menus... |
Audi have been using dynamic indicators since around 2013 so i'm surprised that you being a yorkie muncher you havnt noticed them sooner... and cornering lights have been used the 1960's... ![]() Y. O. L. O. . |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
I've never really fancied the sweeping indicators on mirrors (and you have to buy them). But obviously my car does have cornering lights and despite initially not liking them I wouldn't be without them now as they do light up hedgerows and ditches at night which my forward pointing headlights miss. I know some people don't like them but I'm pretty sure they don't infringe any regulations, if they did thousands of cars would fail the MOT Geoff |
