Home > Maintenance & Mods (L322) > 2011 battery choices AGM 019 ?
Page 1 of 3 123>
GGDR
Hi Team,
Have run the RR around once a week over lockdown and my battery, on it's last legs last winter, finally threw in the towel needing a jump start today.
Had one of those mini jump starter batteries sat there, a last christmas present. Whipped that onto the terminals and boom worked a treat.
A few choices coming up for reasonable sub £150 :
Yuasa
Hankook
Exide
all 95amp, all 850cca
I know a few have fitted the Exides - any experiences or no-gos generally?
Also they all seem to say stop-start... Is that different?
I know I need 091 AGM.
Cheers guys Cheers, Greg
Post #556734 6th Jun 2020 10:20pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I put a 020 in my 2011 4.4 , think it was from energy batteries and cost 160 stg delivered Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #556735 6th Jun 2020 10:24pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Exide agm in mine. I went next size up and it was tight! Very! 2011 4.4tdv8 Vogue
Baltic Blue
Post #556738 6th Jun 2020 10:52pm
coopss
I went for the Yuasa 019 AGM from Tanya batteries - £135 delivered. Few on here had issues getting the 020 fitted.
Spot on so far 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #556753 7th Jun 2020 8:00am
DrRob
This is the one that Mike (BB) has:
https://advancedbatterysupplies.co.uk/product/varta-g14/
https://www.fullfatrr.com/forum/topic49156...3dabc1d84b
Great guide here
https://www.fullfatrr.com/forum/topic43662...11+battery
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #556754 7th Jun 2020 8:23am
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I'd have to check under the bonnet again, but pretty sure when I was fitting the CTEK charger quick connect leads to the Land Rover branded battery in my 5.0 S/C, it also had Exide stamped on it in a few places. Not that I want to restart the brand/OEM argument from another thread...!
Post #556848 7th Jun 2020 8:39pm
mjdronfield
I’m still not convinced as to whether the 020 will actually fit. Some so no, some say yes....some say you have to cut the battery edge..... and some say it’s not even The Stig 🤣
I do all my own jokes....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #556850 7th Jun 2020 8:58pm
019 AGM is fine, the LR is a 90AH exide battery and it’s plenty big enough most of the time.
I would go for the LR one personally (and I did).👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #556852 7th Jun 2020 9:04pm
Baltic Blue
Rob has included a link to the one I bought.
Nearly 3 years later and it still seems a good choice ( touch wood).
Mainly because of the 5 year warranty.
If it fails at 5yrs I will think it has served me well and buy another one.
Post #556856 7th Jun 2020 9:17pm
dolph34
The 020 I put in mine did need to have one plastic lip removed to fit properly.
It was a 1000 cca and 110 ampere hours. I went for it because I use the FBH a lot and found the 019 ( even though checked and found good) used to throw up the ' start engine , battery low ' warning a lot and I would find myself without a toasty car some morning.
Plenty of threads on this with plenty of different opinions, the above is mine Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #556955 8th Jun 2020 7:34pm
mjdronfield
That’s what I’d like to do. Belt and braces and all that.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #556958 8th Jun 2020 7:43pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I'd love to know how you did that Dolph !
Tried to get an 020 in mine and basically the pos terminal was in the way of the side of the plastic box -- I suppose I could have removed the scuttle drain tube - but then faced water on top of the battery !
Really couldn't see how it could be done ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #556959 8th Jun 2020 7:44pm
You cut off one of the bottom side lugs with a hand saw.....
Did it on my 3.6 to make an 020 fit. There is nothing that can't be fixed with a hammer😜😜
Post #556961 8th Jun 2020 7:51pm
GGDR
Cheers for all the replies guys.....
I must admit I'd go for an 020 but hearing equal "it fits" and "it won't fit"
BTW if a battery is "Start/Stop" and AGM and 019 is it any different being marked "Start/Stop" ?
. Cheers, Greg
Post #556965 8th Jun 2020 7:58pm
mjdronfield
Exactly....need a how to hack the 020 guide.....
I’d get garage to fit, but they will prob not want to fit bigger one.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #556970 8th Jun 2020 8:27pm
Page 1 of 3 123>
