![]() | Home > Maintenance & Mods (L322) > 2011 battery choices AGM 019 ? |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I put a 020 in my 2011 4.4 , think it was from energy batteries and cost 160 stg delivered |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
Exide agm in mine. I went next size up and it was tight! Very! 2011 4.4tdv8 Vogue
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I went for the Yuasa 019 AGM from Tanya batteries - £135 delivered. Few on here had issues getting the 020 fitted.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
This is the one that Mike (BB) has:
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
I'd have to check under the bonnet again, but pretty sure when I was fitting the CTEK charger quick connect leads to the Land Rover branded battery in my 5.0 S/C, it also had Exide stamped on it in a few places. Not that I want to restart the brand/OEM argument from another thread...! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
I’m still not convinced as to whether the 020 will actually fit. Some so no, some say yes....some say you have to cut the battery edge..... and some say it’s not even The Stig 🤣
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
019 AGM is fine, the LR is a 90AH exide battery and it’s plenty big enough most of the time.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3809 ![]() ![]() ![]() |
Rob has included a link to the one I bought.
The 020 I put in mine did need to have one plastic lip removed to fit properly.
That’s what I’d like to do. Belt and braces and all that.....
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
I'd love to know how you did that Dolph !
You cut off one of the bottom side lugs with a hand saw.....
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Cheers for all the replies guys.....
Exactly....need a how to hack the 020 guide.....
