![]() | Home > Maintenance & Mods (L322) > 2011 battery choices AGM 019 ? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3809 ![]() ![]() ![]() |
Sorry Landmark but I disagree…and so do JLR.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Fit an AGM. As above, LR soon regretted fitting non-AGM and swapped them out. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
My old one is AGM I believe…. The one I picked up from JLR last week definitely is.
Do it yourself. You don't even need the special torx if you remove the whole bracket via the 10mm nut. Read the whole of this topic: https://www.fullfatrr.com/forum/topic43662.html
How's that battery fairing Dean? I now have a Halfords Trade Card ![]() ![]() https://www.halfords.com/motoring/batterie...48653.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Thanks Rob, AGM it is then I supose!
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 226 ![]() ![]() ![]() |
I recently got a Bosch S5 AGM 019 (I think Bosch call them 013) for £152 delivered from EBay. |
Went for a Varta Silver G14 AGM, 12 V, 950 ah, 850 cca.
