Home > Maintenance & Mods (L405) > dynamic mirror indicators |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
they are not as bright as the headlight indicators when you stand in front of the FF, however when you move to either side the fronts lose brightness and the mirror lights get brighter..
29th May 2020 6:11pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Yours look a lot more bright and vibrant than mine. I’ll see if I can get a vid up. You can barely see them flashing in front of the car even to the side it was pretty lack luster and it was over cast here. If you can’t really see them from the front or a 45* then these are pointless. These are designed to be able to see the dynamic sweep from those angles. 2014 FF Autobiography 5.0 SC
29th May 2020 6:37pm |
29th May 2020 6:48pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Finally got round to fitting them :-
31st May 2020 3:13pm |
nice job Andy....also what you have to remember is that this prolonged spell of good weather is un-usual and when we get our normal dull winter weather these lights will show up even more.. ... - .- -.
31st May 2020 3:35pm |
I agree Stan. A good find by you There'll be even brighter when I get round to washing the car Glad I got a trim removal tool, the mirror covers were a to get off SDV8 AB MY 2019
31st May 2020 3:48pm |
i have to admit that the first cover went flying when i tried to get it off ..i was more careful with the second.. ... - .- -.
31st May 2020 3:50pm |
Seems like mine are definitely dimmer than the both of yours. I’m not happy with mine and will be looking to get a refund.
31st May 2020 5:11pm |
i did and pretty sure Andy did... ... - .- -.
31st May 2020 5:50pm |
Yeh, got mine through Powerful. They do not not look right on yours Horse, far too dim. Assume the connectors are the right way round and fully pushed home? SDV8 AB MY 2019
31st May 2020 7:39pm |
i assume that there are various Chinese manufactures of these units so powerfuluk might have sourced from a different one to you Horse.. ... - .- -.
31st May 2020 7:52pm |
Hey Andy thanks for confirming. On mine there is actually a bit or wire coming off the unit and then a plug. The plug looks the same as the built in socket on the OEM units so it can only plug in and “click” one direction. Not a good pic of the plug but they are the units with the wiring showing.
31st May 2020 7:54pm |
mine came in a foam lined cardboard box so defo different to yours ... ... - .- -.
31st May 2020 7:58pm |
Hi Horse, worth pursuing as they may be duff units. Yeh, the plug should only fit one way as it is rounded on one side. Feel free to use my video to prove what they should look like! :thumbsup SDV8 AB MY 2019
31st May 2020 8:06pm |
