![]() | Home > Technical (L322) > 6hp26 transmission failure on MY08 tdv8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
We are interested mate, it's just that your on new ground, that many being broken here people just get the same one they had....
Thanks for sharing it mate, you are on new ground indeed (like I was with my gearbox issue on the 4.2, also a 6HP26, a few years ago) so very little help to be given.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Some good news. The FFRR is back on the road with a new (used) transmission (not a UK tranny) and transfer box. Its so good to be back in the pilot chair. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
Good that its going again.
thanks Graeme. I think you are on the money again with this. But Ill see how he goes with it.
harlie Member Since: 07 Dec 2012 Location: Brisbane Posts: 4 ![]() ![]() |
Hi Guys
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
This thread relates to shaft failure (through fretting corrosion) for the ZF 6HP26/28 transmission and the Magna Steyr DD295 transfer box. I’m not aware of a similar problem for your GM 5L40-E transmission and New Venture Gear NV225 transfer box. Businesses like JPAT, here in the UK, do list parts for the NV225 :
Hi Phil
Okay, thanks |
Great, thanks Phil. Harlie & I pulled the DD295 out completely the other night for a better look. He had already separated it from trans to get a glimpse of spline condition, it hadn’t let go but was probably close.
Big thinks Phill
When forum member RoverDramas contacted Land Rover about this issue, their reply was “...anti seize grease is applied during the removal and refitting of the transmission. However, this is a service procedure and is not necessarily the same process completed when the vehicle is in the manufacturing process as these parts are fitted dry.”
The input shaft should just slide out once the front casing is removed, though it will still have the pump and suction pipe attached, which will need removing and swapping over onto the new shaft.
Phil |
Thanks Phil. Do you know of the output shaft on 8hp trans fitted by JLR to late L322/D4/L405/L494 vehicles is also dry assembled with D295? ______________________________
I don’t know the answer to that, I’m afraid. I can’t recall anyone posting about this specific issue with the 8HP70 transmission, but I’ve certainly seen reports on other forums of the same spline failures on 2012MY 6HP28 models, so it would seem to be an issue that continued right up to the end of L322 production.
