Home > Technical (L322) > 6hp26 transmission failure on MY08 tdv8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8257 |
We are interested mate, it's just that your on new ground, that many being broken here people just get the same one they had....
23rd Aug 2015 4:21pm |
Thanks for sharing it mate, you are on new ground indeed (like I was with my gearbox issue on the 4.2, also a 6HP26, a few years ago) so very little help to be given.
24th Aug 2015 1:18am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Some good news. The FFRR is back on the road with a new (used) transmission (not a UK tranny) and transfer box. Its so good to be back in the pilot chair.
11th Sep 2015 10:39am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2492 |
Good that its going again.
11th Sep 2015 11:30am |
thanks Graeme. I think you are on the money again with this. But Ill see how he goes with it.
12th Sep 2015 11:42am |
harlie Member Since: 07 Dec 2012 Location: Brisbane Posts: 4 |
Hi Guys
6th May 2020 11:26pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
This thread relates to shaft failure (through fretting corrosion) for the ZF 6HP26/28 transmission and the Magna Steyr DD295 transfer box. I’m not aware of a similar problem for your GM 5L40-E transmission and New Venture Gear NV225 transfer box. Businesses like JPAT, here in the UK, do list parts for the NV225 :
7th May 2020 8:57am |
Hi Phil
7th May 2020 10:14am |
Okay, thanks
7th May 2020 1:36pm |
Great, thanks Phil. Harlie & I pulled the DD295 out completely the other night for a better look. He had already separated it from trans to get a glimpse of spline condition, it hadn’t let go but was probably close.
7th May 2020 10:57pm |
Big thinks Phill
14th May 2020 7:15am |
When forum member RoverDramas contacted Land Rover about this issue, their reply was “...anti seize grease is applied during the removal and refitting of the transmission. However, this is a service procedure and is not necessarily the same process completed when the vehicle is in the manufacturing process as these parts are fitted dry.”
14th May 2020 11:17pm |
Thanks Phil. Do you know of the output shaft on 8hp trans fitted by JLR to late L322/D4/L405/L494 vehicles is also dry assembled with D295? ______________________________
15th May 2020 2:21am |
I don’t know the answer to that, I’m afraid. I can’t recall anyone posting about this specific issue with the 8HP70 transmission, but I’ve certainly seen reports on other forums of the same spline failures on 2012MY 6HP28 models, so it would seem to be an issue that continued right up to the end of L322 production.
15th May 2020 1:12pm |
