![]() | Home > Technical (L322) > 6hp26 transmission failure on MY08 tdv8 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Exactly sir |
Oh and GOOD LUCK |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Thanks, will have a look this arvo. ______________________________
Ok an update, I jacked up and turned each wheel while it was in Park. No noises detected anywhere, and front and rear prop shafts turned as normal. Also, when the engine is running and its in Neutral, the transmission makes the same sound as Drive and Reverse. I'm sure it didn't do that on Sunday when we were getting dragged by another car to a safer stopping location. Finally, it now won't let me select Drive if the engine is running. ______________________________
Has anyone had experience fitting a transmission and transfer box from a facelift L322 3.6 tdv8 to an early L322 3.6 tdv8?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2653 ![]() ![]() |
Different canbus protocol in MY10 I suspect and if so then the TCM is not compatible, contrary to my earlier assessment. The mechatronic might be swappable. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
The above is correct. Same gearbox, but the electronics work on a different CAN-BUS, and not compatible.
Just swapping the TCM and not the valve body is not so straightforward as I understand. A local workshop thought they could put a MY12 6-speed into an early D3 and even after swapping the whole mechatronics still had problems with the box. |
Thanks I forgot about the canbus change. ______________________________
The RR finally went to my usual Indy this arvo.
Fingers crossed here mate. MY 2010 5.0 SC Galway green and sand interior!!
Thanks. ______________________________
The mechanic didn't get a proper look at it today. However, he thinks the noise is from the transfer case. And the noise is the gear in between High and Low range. I'll have to have another look at RRPhil's post on the transfer. ______________________________
I think you are on the money Phil. The Indy has ruled out the electrics on the transfer box. The next thing is transfer box out to check the spline. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Vogue tdv8 08MY poverty pack - wow |
