Home > Technical (L322) > L322 2010 4.4 tdv8 gearbox fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 |
How long had the car been off..?? 12.6 is a fully charged battery, I bet this is dropping overnight, as you turn on the ignition, the gearbox ECU reads the voltage as low and chucks the fault up.... ?? Pete
5th May 2020 10:41am |
Probably the battery then, it's certainly the cheapest thing to try first anyway... Pete
5th May 2020 10:49am |
Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88 |
Exactly, process of elimination. Cheapest thing first. |
5th May 2020 10:51am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 |
even cheaper is a system discharge / battery reset.
5th May 2020 10:58am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
I was getting similar readings to that, but as Haylands says it's probably losing some power overnight, and once they get weak and you turn the key its game over as the voltage drops right down. |
5th May 2020 11:15am |
How do you do the system reset and discharge? |
5th May 2020 11:24am |
It's in the WIKI, just a battery disconnection procedure, worth a try but don't hold your breath...! Pete
5th May 2020 11:50am |
I think I've tried that. Taking battery leads off, then touching them together? |
5th May 2020 12:13pm |
Just got old battery out. There was a label on the breather pipe on old battery dated 18/11/2010 |
5th May 2020 2:02pm |
Oh well new battery in, no difference. |
5th May 2020 3:06pm |
Also I checked new battery charge percentage it was 70%. After I fitted it, I did the battery replacement on diagnostic tool. After that I put charger back on and it was 50%. Getting a replacement tomorrow to see if its the new battery. |
5th May 2020 3:23pm |
Got new battery today. Still the same message. Also noticed not going into low box. |
6th May 2020 6:27pm |
Lo box working, didn't do procedure correctly. |
6th May 2020 6:32pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Interesting - I would have expected a displayed gearbox fault message to have logged at least one DTC indicating as to why it was showing you the message - what did you read the codes with? |
6th May 2020 6:43pm |
