![]() | Home > Technical (L322) > L322 2010 4.4 tdv8 gearbox fault |
Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88 ![]() ![]() ![]() |
I used the autel maxi Pro. Going to try someone else tomorrow and see what they can do. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
The connector contacts at the ecu (TCCU) can become corroded. I suggest that the connectors be inspected.
What's the tccu? |
The ecu - Transfer Case Control Unit. |
And it's beside the brake master cylinder? |
