Home > Maintenance & Mods (L322) > If I were to invest in a OBD Scan Tool
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Which one ? For my Merc its easy. For the FFRR the offerings seem bewildering in terms of what can or cannot be acheived with one.
What do you guys use ??
Post #551692 26th Apr 2020 10:43am
IID tool from GAP is by far the most popular on here
Post #551693 26th Apr 2020 10:54am
PeteT80
+1 for IID Tool. Ideally Bluetooth version. Thumbs Up
Post #551695 26th Apr 2020 11:03am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
After-sales is the top for IID tool Thumbs Up
Post #551696 26th Apr 2020 11:15am
Brian Considine
I know the GAP II is highly regarded on here but to me it seems a little expensive as you need another device (such as a smartphone or laptop) to use it and you can only use it on a dedicated vehicle. 2003 Range Rover Vogue TD6
Post #551698 26th Apr 2020 11:16am
darrenm
Iid tool for me
Post #551699 26th Apr 2020 11:24am
ur20v
A Trap
iID tool for me as well.
It’s a pity it won’t double as a generic ‘basic’ tool for all other manufacturers and read basic OBD codes.
Post #551704 26th Apr 2020 11:54am
DrRob
Gap IID Bluetooth Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551706 26th Apr 2020 12:01pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Gap IID Bluetooth without a doubt Thumbs Up Thumbs Up Thumbs Up support from patrick is second to none Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #551708 26th Apr 2020 12:15pm
Dolphinboy
I think it will identify faults and clear them on other vehicles but you don't get the whole suite of adaptations that the registered vehicle gains. Anyone clarify/confirm that?
Post #551709 26th Apr 2020 12:15pm
Weegie
It will read and clear faults on other vehicles of the same type although you can't use it to change the CCF. John
GAP iiD BT
Post #551710 26th Apr 2020 12:15pm
Yep, you can't beat an IID tool, the customer service is second to none, any issues or problems and they will get to the bottom of it for you, that's priceless on it's own.. Pete
Post #551713 26th Apr 2020 12:29pm
Ragingrover
OK so its this one @ £400 ???
https://www.gap-diagnostic.com/shop/iidtool-bt/
Post #551721 26th Apr 2020 1:07pm
plus vat and customs tax.
i would look in the for sale sections on this and our other sister forums for used ones, much cheaper.. ... - .- -.
Post #551722 26th Apr 2020 1:13pm
WB
I've owned two - the iCarSoft LR II - around £150 from amazon - this will read codes and live values and reset service lights and clear fault codes. It will also do some more advanced functions like reset engine adaptions. Perfectly good scanner.
As I was able to buy a used one at a good price I bought the GAP IID tool which does the above and a few other more specific Land Rover things like setting custom suspension heights and being able to calibrate the suspension which I found very useful.
I've kept the IID mainly because I will probably be able to sell it for the same if not very close to what I paid for it.
Contrary to the experience of others I haven't found the customer support to be great. While they usually respond quickly they don't seem to want to do very much to investigate issues. For example there are some live values I know the LR Specialist system (SSD IIRC) can read but they don't show up on the IID. When I asked GAP support there response was 'we expose everything LR presents' - clearly this isn't the case as I've seen the values with my own eyes and they're not at least clearly found on the GAP tool. Unfortunately they showed no willingness or eagerness to try to help me further. Not what I call good service especially for how much the device costs.
Post #551738 26th Apr 2020 2:27pm
