Home > Maintenance & Mods (L322) > If I were to invest in a OBD Scan Tool
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
I'll keep my eyes open and see if I can find a used one then. Right now it's more of a nice to have as I've got no real issues (yet!) I have to say that compared to other devices that can read multiple manufacturers systems, they are bloomin expensive !
Post #551750 26th Apr 2020 3:19pm
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
bought this
https://www.foxwelltech.com/product/item-169.html
4 years ago, it did the trick for my defender td5 and lr3, and does a few things on my l405
was even allowing to program keys and height on the lr3, but not on the l405 Sad 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #551774 26th Apr 2020 6:44pm
DrRob
Had an icarsoft lr2 it the IID is light years ahead. Bluetooth and app driven off phone Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551779 26th Apr 2020 8:20pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I currently have two, I started with the Hawkeye Total which does everything the IID tool can apart from modifying the CCF files, however, it can do a DPF regen. The downside is it's cable that plugs from the OBD port to the Unit itself, it's quite thick and cumbersome at times. I decided to opt for the IID tool as well after reading so much about it here. If I were to decide between the two, I would probably suggest the IID tool as it's compact and covers most of what you will ever need. The cost seems high to begin with but once you have used it a few times it's paid for itself, especially if you consider a diagnostic charge can be in excess of £75. I bought mine direct from GAP and with customs charges it came in around £450, they can be had cheaper if you look around, I should have taken advantage of the Duckworths sale of £405 when Dan was there but dithered too much.
Post #551792 27th Apr 2020 9:35am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
IID great tool, aftersales service is not what I expected after reading the forum. Being a non tec, the forum reactions about aftersales where the reason to buy. But there I am seriously disapointed.
Post #551817 27th Apr 2020 12:44pm
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
I recently ordered jlr ssd from ebay, so I will write up in a seperate topic what it can do and is it to complicated for diy use.
Icarsoft v2.0 is all the time in the car, and I am happy with it for basic maintainance. It only lacks suspension height adjustments, then it would be the best bang for buck. Cool RR HSE 4.4 2006 LPG
Post #551905 28th Apr 2020 7:42am
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
https://www.island-4x4.co.uk/integrated-in...27303.html
Post #551912 28th Apr 2020 8:45am
