![]() | Home > Technical (L322) > 4.4 TDV8 Throttle Body |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
My clip give way leading to restricted and DPF full.
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Cheers Greg
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1296 ![]() ![]() ![]() |
There is a green 2 lipped rubber seal further into the pipe that slides over the throttle body to make the seal. The clip is basically to hold it in place. You can't buy the seal separately though. I know because my pipe felt loose and had a bit of oily residue at the connection. It's got the full force of the turbo blowing through it and I think it could have been designed better. Cheers Kev. |
Hi Kevin, certainly something to check. The idea of a seal makes perfect sense to me, bit crazy that you can't buy it seperatley though especially as it's an item that could perish over time. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2645 ![]() ![]() |
The temperature sensor that is fitted in the plastic pipe can't be purchased separately either. |
Got round to looking at this today. There was definitely some oil/soot residue on the underside so this has now been cleaned up. I took the rubber seal out and gave this a clean and inspected it for any splits but couldn’t see any. Reseated this and carefully slid the plastic back over the throttle body. Annoying that you can’t just buy a new seal as I’m sure over time it will become compressed and less able to seal properly. Once I’m able to get out and take it for I will be able to see if any oil/soot starts to reappear |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
How is the clip removed to remove the pipe? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Here you go Rob
It's a lot easier to get off if you remove the rubber hose completely from the intercooler first. Less chance of breaking that delicate water connection that goes over it. Then with a screwdriver gently pry the clip out of its locating slots. Just make sure you bend it to a complete circle before putting it back on with the split at the bottom. |
Stripped mine down today as a bit of preventative maintenance. The clip was loose so bent it back into shape a bit like Greg did. Not sure it made a huge amount of difference. Little bit of oily soot underneath but not too fussed as I’ve not had any issues to date...touch wood |
I’ve bought a new throttle body to intercooler plastic elbow |
New:
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
MAF 2011 4.4tdv8 Vogue
I wonder if you could get a silicone hose to go over the tb and this plastic intake. |
