Home > Maintenance & Mods (L322) > LED interior upgrade |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Looks great.
11th Apr 2020 7:17am |
Any tips, anything difficult or you would do differently? |
Panoramix Member Since: 18 Mar 2016 Location: Milan Posts: 22 |
You need to remove a lot of trim.
11th Apr 2020 7:43am |
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 |
It looks perfect , has you more pics from the parts and building
11th Apr 2020 9:04am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
How do you remove the instrument needles? I pulled them on my original l322 and wrecked the motors - I have the same style one as you now and need to get them off wondered if any different? Current stable:
11th Apr 2020 9:13am |
For the earlier L322 is very very easy broke them pulling out.
11th Apr 2020 12:38pm |
I'm sorry FrankN, I didn't. |
11th Apr 2020 12:46pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Could you list the parts required? John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
11th Apr 2020 12:52pm |
Only SMD 3.5 LED, soldering iron and patience.
11th Apr 2020 5:39pm |
Thank you. John
11th Apr 2020 5:40pm |
What’s the safest way? Maybe slide a fork in and gently lever out? Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
11th Apr 2020 5:49pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
If you are removing any instrument gauge needles, you should use one of these to avoid pulling the shaft away from the driving mechanism.
11th Apr 2020 5:58pm |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
Great job Panoramix and kudos for the attention to detail.
11th Apr 2020 6:15pm |
Hi thanks for the tips - what leds did you use as I may do mine can you get different brightness as I had white ones fitted to my old l322 and they were so bright at night but I couldn’t turn down the rheostat as you couldn’t see the green on anything else... Current stable:
17th Apr 2020 10:57pm |
