Home > Maintenance & Mods (L322) > LED interior upgrade
Guihan
United States 2007 Range Rover HSE 4.4 V8 Stornoway Grey
Looks like a lot of work, but the finish product looks great.
Post #550947 19th Apr 2020 10:13am
Panoramix
Italy
Danwilderspin wrote:
Hi thanks for the tips - what leds did you use as I may do mine can you get different brightness as I had white ones fitted to my old l322 and they were so bright at night but I couldn’t turn down the rheostat as you couldn’t see the green on anything else...
Standard SDM 3.5. They still dimmerable like the orginal so you cn regulate it.
A little trick, if adjusting the brightness to the minimum set the light switch not on "Auto", the brightness will dim further Thumbs Up
Post #551057 20th Apr 2020 4:51am
Danwilderspin
These kind?
https://www.ebay.co.uk/itm/200914611135
How many roughly in the cluster? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551070 20th Apr 2020 8:27am
Panoramix
Italy
yes, they can be ok Thumbs Up
Post #551089 20th Apr 2020 11:06am
Danwilderspin
Took the cluster apart (well a spare) and comes apart easy, but 30 SMDs just in the closet - and the new ones I bought don't have an obvious direction... doh! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #551791 27th Apr 2020 8:58am
Danwilderspin
How are you getting on with this? Do you have the exact smd you used?
My two needle leds have burnt out and looking on the sport forum this happens if they draw too much power through the tracks and burn them out ... not had it out yet but definitely plausible if they use twice as much power... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #576249 15th Dec 2020 1:08pm
