Home > In Car Electronics (L322) > Ulf Range Rover Bluetooth upgrade
Lee1974
England 2002 Range Rover Vogue 4.4 V8 Java Black
Hi I’ve seen a thread about shorting pins 32 and 36 were not got a switch fitted to put ulf into pairing mode could any help off how to short them I’ve got activate phone in grey but can’t pair
Thanks in advance
Post #549772 9th Apr 2020 3:27pm
mjdronfield
You have to short them together with them still connected, if that makes sense.... ie you are earthing one of the wires through the other, as one is ground. Sorry, can’t remember which one. It’s years since I did it. Think there is a procedure somewhere....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #549781 9th Apr 2020 6:18pm
Lee1974
So put pin 32 in as 36 is already installed and then with the wire off pin 32 sort touch pin 36 that right
Post #549782 9th Apr 2020 6:25pm
mjdronfield
More info on here, first 2 pages.
The procedure is there too.....
But yes, the brown wire is Earth for the ULF and still needs to be earthed when you short the white wire to it.
https://www.fullfatrr.com/forum/topic14122...lf+pairing
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549783 9th Apr 2020 6:28pm
mjdronfield
You don’t need to get into the pins.... anywhere on the brown wire can be used to short to....I cut it and joined up again with a choccy block. Then I pushed the white wire into the metal bit on the choccy block to short to it, hence leaving the brown wire still fully connected and grounded. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549784 9th Apr 2020 6:32pm
Lee1974
Still lost lol
Pin 36 is still conected to ulf
Pin 32 just a strand wire so do I just touch pin 36 while it’s conected
Post #549785 9th Apr 2020 6:32pm
mjdronfield
Wire on pin 36 should be brown. Fully connected up.
Wire on pin 32 doesn’t actually go anywhere....short it to the brown wire that’s on 36... but 36 still needs to be grounded, so don’t disconnect it.
Simply shorting pins 32 and 36 will have no effect whatsoever.... you need 36 to still go to ground...
If that makes sense.
I took one of the unused pin connectors and put that on 32 so I had about 4 or 5 inch of wire to play with and was much easier. You prob figured that already.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549786 9th Apr 2020 6:48pm
Lee1974
Ok I get it now lol so if I cut brown wire pin 36 and join up with a block conector
Put pin 32 with some wire on and basically touch the block conector withe 32s wire
Does the ingition need to be on wen do it then see how for car with my phone bt
Post #549789 9th Apr 2020 7:14pm
mjdronfield
Yes, that’s how to do it, but you need to then follow the pairing procedure that’s in the other thread I linked to.
You will get the 3 lights on near the dash screen if I remember right. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549790 9th Apr 2020 7:22pm
mjdronfield
-With the ignition off, press and hold the pairing button on the cradle (not the wheel).
-Hold for 5 seconds, then turn the ignition to the accessory position, the monitor should say 'Bluetooth Pairing' and the small LEDs on the monitor will flash.
- On your phone, search for bluetooth devices, select the BMW one and enter the 4 digit pin that is on the part number sticker of the ULF.
- You should hear a beep and see 'Pairing successful' or some such.
- Cycle the ignition to exit pairing mode, see if your phone connects. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549791 9th Apr 2020 7:25pm
Lee1974
Not got pairing button ?
Post #549793 9th Apr 2020 7:39pm
mjdronfield
The pairing button is you shorting the wires together..... so you will have to short them in the boot...dash to the front to turn key and then dash back to separate the wires etc.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549795 9th Apr 2020 7:59pm
Lee1974
Ok I got it so connect them got turn key dash bk to rear I short them then should see show up on phone
Post #549797 9th Apr 2020 8:03pm
Lee1974
Are u from Kirkby in Ashfield thought seen you motor around by there ?
Post #549802 9th Apr 2020 8:56pm
mjdronfield
I’m in Chesterfield.
You have to get the timing right with the sequence. Keep trying it if it doesn’t work first time. You have 5 seconds to get to the front.... Rolling with laughter
You should be able to see if it’s worked from the boot by looking between the headrests at the screen in the front....you will see the 3 lights on.
I eventually put a switch in, but you only need to pair your phone once, so you can manage without if you want to....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549806 9th Apr 2020 9:28pm
