Home > In Car Electronics (L322) > Ulf Range Rover Bluetooth upgrade |
Lee1974 Member Since: 09 Apr 2020 Location: West midlands Posts: 14 |
I will eventually fit a switch is That easy cus I’m always changing my phones lol |
9th Apr 2020 8:37pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7788 |
I just put it on the wires in the boot, then tucked it away....nothing fancy. 2011 Range Rover Vogue SE 4.4 TDV8
9th Apr 2020 8:51pm |
I didn’t have that issue....can only suggest checking wiring. Take it you have not got the pins shorted now.....
10th Apr 2020 3:29pm |
Yes all paired and can go through contacts aswell just can’t hear anything pins shorted fine m8
10th Apr 2020 3:32pm |
Think pin 51 is the mute signal.
10th Apr 2020 3:38pm |
Can’t hear nothing at all so don’t now wen connected all the wires seem mixed up the red wire not attached or yellow or pin 51 |
10th Apr 2020 3:42pm |
The cable that was on pin 29 should now be in 51.
10th Apr 2020 3:50pm |
I apreshiate you help I’m goin off the colours on a listing
10th Apr 2020 3:55pm |
I’m not sure, it’s not my chart. I just moved the cables from pin to pin without looking at colours.
10th Apr 2020 4:13pm |
Looks like that’s correct....
10th Apr 2020 4:17pm |
Thanks for that info I’ll have another look tomoz got all working with radio mute and I can hear people but they can’t hear me so just the mic to sort out lol |
10th Apr 2020 4:54pm |
Getting there mate. There aren’t really that many wires that it actually uses. 2011 Range Rover Vogue SE 4.4 TDV8
10th Apr 2020 5:42pm |
