Home > Technical (L322) > Restricted Performance
Page 3 of 3 <123
Baltic Blue
I am surprised that you say”rust” because the outer case and pipes are stainless steel, so I presumed that the inners would also be made of stainless steel ?
Post #547007 13th Mar 2020 2:59pm
jc132jc
I’ve just tested my new DPF, the pipes and DPF body are steel, the heat shields are stainless steel and the pipes that run across the top of the DPF are stainless steel.
Post #547009 13th Mar 2020 3:13pm
jc132jc
Hi everyone, as promised here is a photo of my knackered DPF, Iam surprised any exhaust gas could get through that ! Shocked
Post #547590 19th Mar 2020 1:22pm
Baltic Blue
Have you sent the picture 2nd class post ?? Rolling with laughter
Post #547591 19th Mar 2020 1:33pm
jc132jc
Laughing How to I post a photo?, its in my gallery if you guys can see it?
Post #547593 19th Mar 2020 1:45pm
DrRob
[/img] Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #547594 19th Mar 2020 1:53pm
DrRob
Post #547595 19th Mar 2020 1:53pm
Baltic Blue
Stan will probably help you better, but if you can see it in the small images below your text, then click on it and it will be added to your post.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #547596 19th Mar 2020 2:01pm
Baltic Blue
Well done Rob Thumbs Up
Is the soot solid, set like concrete ?
Post #547597 19th Mar 2020 2:04pm
jc132jc
Mike, yes, hardened ash, I did try and scrap some off but no, it’s certainly not going anywhere.
Post #547628 19th Mar 2020 6:50pm
RRD
Belgium 2012 Range Rover Vogue TDV8 Santorini Black
jc132jc wrote:
Hi guys, just a quick update on my ongoing issue. After a lot of diagnostics and test runs, regens and so on I can confirm my problem is indeed a block DPF, but not with soot, hardened ash/rust deposits, so the honeycomb in the DPF is about 70 % blocked, as you can imagine it only takes a little soot to block it and cause problems, unless you continuously drive at 50mph.
So the great guys at my local garage are trying there best to clean/remove the ash/rust deposits, fingers crossed, but if they cannot then its a new DPF for me. OUCH Big Cry
I don't think there is anything I could have done to prevent this just an age related issue.
Sorry for bumping an old thread, but I'm currently having similar problems as you which are going on for some time now. I'm at the point where I haven't driven the car for months because I've checked everything I find on these forums. High pressure smoke test didn't show any leaks and I have a 2012 TDv8 so I have the updated hoses anyway.
How did you finally get to this solution? There's no way to look 'in' to the DPF and see the honeycomb, so how did you or your garage find out? '17 Range Rover 5.0 Supercharged AB (Sold)
'16 Range Rover SDv8 AB (Sold)
'15 Range Rover SDv8 Vogue (Sold)
'13 Range Rover SDv8 Vogue (Sold)
'12 Range Rover TDv8 (Sold)
'10 Range Rover 5.0 Supercharged
'03 BMW E39 M5
'01 BMW E46 M3
Post #612066 8th Nov 2021 5:41pm
jc132jc
Hi, they ended up cutting it out as and looking in with a camera, just make sure if you go down the route it’s cut in the correct places or you will end up with several joints in the exhaust.
Good luck
Post #612083 8th Nov 2021 8:38pm
Page 3 of 3 <123
