Home > Technical (L322) > Where did that cloud of smoke come from? |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Have you checked for oil in the V?
13th Mar 2020 7:27am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Hi Mike, thanks for the response
13th Mar 2020 8:10am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I am not sure why you should have a smokescreen at a standstill while idling but the on the move one when hammering the throttle sounds very much like the usual "turbo drain mod not done".
13th Mar 2020 2:01pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3771 |
I got the mod done on mine whilst it was still under warranty, after I took the service manager out for a little run then booted it down a motorway slip road whilst he was looking back. Even he said, “ it’s pretty bad isn’t it “
13th Mar 2020 2:10pm |
Drove home tonight on motorway sitting at 65mph no further DPF light which was a blessing. Got stuck behind a tractor for about 2 minutes when close to home which isn’t unusual and meant crawling along at 10mph. Finally got past tractor and stopped at the next junction only to have the smokescreen reappear. As no one was behind me I just thought I would watch and see how long it would take to clear if I didn’t touch the accelerator. Took about 20 seconds to clear in total and a tiny puff when I pulled away again.
13th Mar 2020 5:08pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
I had this for a while. Main reason is I didn’t get the second turbo in enough, so oil built up, came out when I accelerated.....then cleared.
13th Mar 2020 5:49pm |
The symptoms you are describing do not suggest you need to do the turbo. drain mod.
13th Mar 2020 5:54pm |
Hi Mike I know what your saying about the valve guides and wear but I have no smoke on start up and car has just turned 116,000. This smoking issue seems more like the car has decided to do a full regent once I’m stationary, all very odd.
13th Mar 2020 7:17pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 |
Have you got an IIDTool?
13th Mar 2020 9:11pm |
Hi Greg, no IID tool I'm afraid, I do have a Hawkeye Total but not sure if that will give me soot readings or regen information but will take a look and let you know. |
14th Mar 2020 7:51am |
Just found this about different types of DPF regeneration
14th Mar 2020 8:32am |
Plenty more info here:
14th Mar 2020 8:45am |
OK so I have run some diagnostics but to me I would say that the information given on some of the screens in inaccurate.
14th Mar 2020 11:00am |
Yes they are definitely related in my view
14th Mar 2020 11:41am |
