Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1778 |
So, both cars have EGR blanks, and both cars have exactly the same symptoms, and you don't see that they may be causing your issues? Id rather waste an hours time removing the blanks and run it for a few weeks to see if the symptoms improve... |
1st Feb 2020 8:09am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 684 |
I dont see how blanks can be causing my issues on either car when they were fitted to both for months before any issues showed up. Over 5 months on this car!
1st Feb 2020 10:05am |
They would make a difference, as when the PCM commands the EGR valves to open, the throttle body butterfly closes (in both bodies) , to allow the engine to suck in the EGR gasses
1st Feb 2020 2:02pm |
I understand that Mikey and it does completely make sense to me
1st Feb 2020 2:22pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2523 |
I would monitor the coolant temperature sensor in case of a poor electrical contact on its connector which may be getting bumped or its wiring bumped during hose R&R. |
1st Feb 2020 8:45pm |
Two new genuine LR upper intercooler hoses fitted tonight.. no difference.
1st Feb 2020 10:15pm |
You might want to monitor the sensor while manipulating the harness. The movement of the engine under load could be opening-up a break in a wire. |
1st Feb 2020 11:45pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Have both vehicles had the same EGR blank and remap (from the same company)?
2nd Feb 2020 12:39am |
Will do Graeme ,
2nd Feb 2020 8:04am |
What year engine? 2007 3.6 TDV8 |
2nd Feb 2020 9:14am |
This one is a 2010 3.6 tdv8 facelift |
2nd Feb 2020 9:16am |
My understanding is that from around 2007 onwards, it’s not possible to get away with blanks and not remapping.
2nd Feb 2020 10:11am |
Egrs blanked and no check engine light for months. I've tried unplugging the EGRs, doesnt affect how it drives. |
2nd Feb 2020 10:13am |
Not sure how to attach files but here is a google drive link to some data from the IID tool.
2nd Feb 2020 10:17am |
