![]() | Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
| S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170
I got EGR fault codes after installing the blanks, never had them before. I did however monitor EGR-movement before installing the blanks, and the problem most certainly existed before installing the blanks.
| uzp315 Member Since: 19 Nov 2017 Posts: 428 |
110k miles/3.6 tdv8 Starting to consider my options with the EGRs.
| RRluvva Member Since: 15 Oct 2019 Location: Fife Posts: 6
I blanked mine and so far its the best £35 quid I've ever spent in a long time! I had intermittent EML post blanking but now the EML has gone completely.
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
Before considering reconditioned EGRs, it might be worth remembering that the worst possible failure mode of the EGRs is that the valve head breaks up & gets digested by the engine & turbos.
Good info Pawl
RRLuvva, yes, but you don't know what is going on inside the blanked unit. Every action has a reaction. That gunk is still building up and has to cause other errors at some point unless you get a delete. .But then you have still blanked off one of the exit routes for that gunk....so now it is is going down towards your CAT. Might be fine...but does anyone know for sure?
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Deleted |
If correct, that would answer why it is an improvement - thanks ur20v.
Deleted |
I have decided to join the club. Parts ordered, magnetic pick up tool ordered. Will check to see if I have a T30 torx. Thanks everyone, makes me happy to be able to find all this good information. I am old enough to remember life before the internet when getting info like this, and answers to questions was very hard indeed. So....
Deleted . |
| Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282
Mines on 189,000 now with no turbo smoke on hard acceleration, starts and runs no problem but I think fuel consumption is about the same so far so good |
All done. Tested for about 60 miles so far. All good.
Deleted |
| All times are GMT |
