Home > Technical (L322) > Removing CVD dampers and replacing for standard |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2555 |
I would expect that changing the CCF setting for CVDs to not-fitted would do the job although you might also have to remove the CVD power supply fuse.
13th Jan 2020 10:21am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 693 |
My problem with the CVDs is they are so stiff.
13th Jan 2020 10:38am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Try changing the CCF and unplugging the shockers... Go for a drive and see if it flags up an error... |
13th Jan 2020 10:45am |
Did your 09 have 20" rims and does your friend's 07 have 20" rims? Even if they were both 20" the difference in ride of different tyre brands can be significant.
13th Jan 2020 11:24am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
I've got the opposite problem on mine and I'm running 21s.
13th Jan 2020 1:17pm |
My 09 had 20 inch alloys with 255 50 20 toyo proxes t1 SUV.
13th Jan 2020 2:04pm |
Kooky does yours have cvd damping?
13th Jan 2020 2:05pm |
Sorry for all the posts but I felt I should clarify that I have driven a 2011 4.4 tdv8 with CVD which is fitted with the 255 50 20 avons I removed from mine and the ride is just as terrible. |
13th Jan 2020 2:09pm |
Replacing the front struts with non-genuine non-cvd versions sounds like it may be worthwhile for you, noting that the rear cvds will be at their default firmest for the test. If that makes the ride at the front what you want then continue with replacing the rears and disabling cvds in the ccf. Ensure that the removed shocks/struts are stored upright if storing for an extended time. |
13th Jan 2020 7:50pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 |
I went from a non cvs 07 to a 12 plate CVD car. The 07 on Michelin Diamaris and the 12 on Pirelli. Mine doesn’t crash over potholes.....tbh I cant remember there being a massive difference in the ride quality between the 2 cars. The 21 May corner a bit flatter, but on the crap B road to my village which has many pot holes, they were very similar if I remember .
13th Jan 2020 8:15pm |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
Could this be an electrical problem ? the reason i say this is that i have the same problem on a 2016 L405 and every so often
13th Jan 2020 9:12pm |
Sounds very similar aljo.
13th Jan 2020 10:02pm |
If I can manage to understand why the ride is better with the dsc switched off then I may be closer to solving the puzzle
13th Jan 2020 10:34pm |
Switching off DSC on both the L322 and L405 (and L494 too) increases damper stiffness. If the ride is smoother with DSC off then the dampers aren't working properly, possibly due to the seals being worn allowing too much fluid to pass or the mechanical valves not sealing properly. Try with DSC off but if not enough of a change then remove the connector from the top of 1 front strut as this totally disables the softening of all dampers . The ride should be very firm as this is maximum firmness but if the ride is now much better then the dampers are much too soft due to wear or valve failure.
14th Jan 2020 2:34am |
