Home > In Car Electronics (L322) > Entertainment system reset.
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
The screen on our 2006MY TD6 is just displaying the Land Rover logo and the LED on the power button is flashing. Do I need to reset it? The battery did go flat a couple of weeks ago, so I am hoping this is the cause. Which fuse do I pull to power it off?
Thanks, Glen.
Post #538170 22nd Dec 2019 1:07am
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
This can be caused by one of the modules on the MOST system going down, possibly due to water ingress. The Nokia blue tooth module is a favourite. If you can bypass the fibre optics on each module in turn you may find the culprit when the system springs back to life. RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #538249 22nd Dec 2019 6:30pm
GDM
Thanks. I will check for water ingress. It did do this once before and it came back to life again. As I say, this time it may be something to do with the battery going flat.
Can anyone tell me the part number for the BMW ULF Bluetooth unit that can be fitted to the MOST system on the L322?
Post #538269 22nd Dec 2019 10:22pm
GDM
I had some time to look at this again today.
I tried the reset and that didn't work. There wasn't any serious water ingress in the boot where the entertainment equipment is housed but I did fid a bit of corrosion on some of the pins in the Bluetooth module. Cleaned the connector with contact cleaner but still no luck.
I do have a hybrid tuner I could swap for the terrestrial unit that is in the car, to eliminate that being at fault. I tried connecting it some time ago and it worked fine but I haven't had time to make up brackets to mount it permanently yet.
I am going to try and find a later Bluetooth module to eliminate my one being at fault, rather than mess about with the fibre optic connectors.
It's very annoying that it has packed up now, as I had planned to get the DTV working and a new reversing camera fitted over the Christmas holiday.
Post #538635 27th Dec 2019 7:26pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Just unplug the fiberoptic cable to the bluetooth and connect a bypass connector they are £20 on ebay this does the job until you buy a new bluetooth module. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #539591 6th Jan 2020 11:39am
..or you could try a 'cut down' bic biro instead of spending £20.. ... - .- -.
Post #539596 6th Jan 2020 12:09pm
GDM
I am probably going to have to try the Bic biro method, as even a standard Bluetooth module seems to be about £100 + on e-bay. If that works then I don't mind replacing the module.
Post #539677 6th Jan 2020 10:43pm
GDM
Had another look at this today.
I checked the 3 fuses behind the glovebox and they are all fine. I substituted the hybrid DTV box for the analogue one and that made no difference. So I thought I would try the biro method on the fibre optic cables to bypass the Nokia Bluetooth unit. I removed the blue clip but I couldn't get the fibre optic cables to pull out of the black connector. Am I missing something here? If they won't come out I can get a female bypass connector on e-bay for £7-00.
Also, what does the TMC unit do? That has fibre optic cables connected to it too.
Post #540238 11th Jan 2020 6:39pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
£4 on eBay, look for Most fiber-optic bypass.
Mine took a while as it ships from China, sadly I've not established which ones causing it though.
https://m.ebay.co.uk/itm/NEW-MOST-fiber-op...24a881cd59 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #540254 11th Jan 2020 9:00pm
GDM
Thanks, I did see those but £7-00 from a UK supplier and free delivery by Wednesday seemed a better option.
Post #540264 11th Jan 2020 9:53pm
GDM
Tried again today and still couldn't get the fibre optic cables to come out of the black plug. However, I did notice that I have a red light at the incoming fibre on the Nokia unit but when I plug it back in, I do not have a red light at the incoming fibre on the TV tuner, which is next in the fibre optic loop.
Seems to be fairly conclusive that it is the Nokia unit at fault.
Post #540329 12th Jan 2020 5:12pm
