![]() | Home > In Car Electronics (L322) > Entertainment system reset. |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 ![]() ![]() ![]() |
This can be caused by one of the modules on the MOST system going down, possibly due to water ingress. The Nokia blue tooth module is a favourite. If you can bypass the fibre optics on each module in turn you may find the culprit when the system springs back to life. RR History
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
Thanks. I will check for water ingress. It did do this once before and it came back to life again. As I say, this time it may be something to do with the battery going flat.
I had some time to look at this again today.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Just unplug the fiberoptic cable to the bluetooth and connect a bypass connector they are £20 on ebay this does the job until you buy a new bluetooth module. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35619 ![]() ![]() |
..or you could try a 'cut down' bic biro instead of spending £20.. ... - .- -.
I am probably going to have to try the Bic biro method, as even a standard Bluetooth module seems to be about £100 + on e-bay. If that works then I don't mind replacing the module. |
Had another look at this today.
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
£4 on eBay, look for Most fiber-optic bypass.
Thanks, I did see those but £7-00 from a UK supplier and free delivery by Wednesday seemed a better option. |
Tried again today and still couldn't get the fibre optic cables to come out of the black plug. However, I did notice that I have a red light at the incoming fibre on the Nokia unit but when I plug it back in, I do not have a red light at the incoming fibre on the TV tuner, which is next in the fibre optic loop.
