Home > In Car Electronics (L322) > Entertainment system reset. |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 |
This can be caused by one of the modules on the MOST system going down, possibly due to water ingress. The Nokia blue tooth module is a favourite. If you can bypass the fibre optics on each module in turn you may find the culprit when the system springs back to life. RR History
22nd Dec 2019 6:30pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Thanks. I will check for water ingress. It did do this once before and it came back to life again. As I say, this time it may be something to do with the battery going flat.
22nd Dec 2019 10:22pm |
I had some time to look at this again today.
27th Dec 2019 7:26pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
Just unplug the fiberoptic cable to the bluetooth and connect a bypass connector they are £20 on ebay this does the job until you buy a new bluetooth module. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
6th Jan 2020 11:39am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
..or you could try a 'cut down' bic biro instead of spending £20.. ... - .- -.
6th Jan 2020 12:09pm |
I am probably going to have to try the Bic biro method, as even a standard Bluetooth module seems to be about £100 + on e-bay. If that works then I don't mind replacing the module. |
6th Jan 2020 10:43pm |
Had another look at this today.
11th Jan 2020 6:39pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
£4 on eBay, look for Most fiber-optic bypass.
11th Jan 2020 9:00pm |
Thanks, I did see those but £7-00 from a UK supplier and free delivery by Wednesday seemed a better option. |
11th Jan 2020 9:53pm |
Tried again today and still couldn't get the fibre optic cables to come out of the black plug. However, I did notice that I have a red light at the incoming fibre on the Nokia unit but when I plug it back in, I do not have a red light at the incoming fibre on the TV tuner, which is next in the fibre optic loop.
12th Jan 2020 5:12pm |
