Home > Maintenance & Mods (L322) > Is this smart charger / battery conditioner suitable? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Can't think of any reason why it wouldn't be suitable for your intended usage. |
30th Nov 2019 10:57am |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
I use a lowly old CTEK 3.6 which is rated to 120ah too. It takes a while longer than a mates CTEK 7.0 which I have also tried, but it is perfectly capable of handing the battery in my Westie. On this basis I can't see why the Maypole isn't up to the job. Current: FF Westminster money pit
30th Nov 2019 1:58pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Good thing about Ctek is if you have towing electrics then you get an adaptor to charge the battery via tow socket
30th Nov 2019 3:28pm |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 |
I did see those and they do one for the SAE type connector that is on the maypole chargers. I do have the twin plug at the back too. I was going to get one but then thought just hard wiring to the battery and having it poking through the bonnet by the windscreen underneath the lip would be preferable to routing around under the back of the car each time I want to connect or disconnect. So far it’s working well like that. |
30th Nov 2019 4:17pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
I had a quick look on Amazon and could only find a MP7423A at £22.99 or a MP7423 at £36.59. Is it the “A” your referring to?. Might get one actually |
30th Nov 2019 4:53pm |
This is the one.....
30th Nov 2019 5:23pm |
TVM. |
30th Nov 2019 5:45pm |
