![]() | Home > Maintenance & Mods (L322) > Is this smart charger / battery conditioner suitable? |
Can't think of any reason why it wouldn't be suitable for your intended usage. |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
I use a lowly old CTEK 3.6 which is rated to 120ah too. It takes a while longer than a mates CTEK 7.0 which I have also tried, but it is perfectly capable of handing the battery in my Westie. On this basis I can't see why the Maypole isn't up to the job. Current: FF Westminster money pit
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Good thing about Ctek is if you have towing electrics then you get an adaptor to charge the battery via tow socket |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
I did see those and they do one for the SAE type connector that is on the maypole chargers. I do have the twin plug at the back too. I was going to get one but then thought just hard wiring to the battery and having it poking through the bonnet by the windscreen underneath the lip would be preferable to routing around under the back of the car each time I want to connect or disconnect. So far it’s working well like that. |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 ![]() ![]() |
I had a quick look on Amazon and could only find a MP7423A at £22.99 or a MP7423 at £36.59. Is it the “A” your referring to?. Might get one actually |
This is the one.....
