Home > Technical (L322) > Flip key conversion?
Page 3 of 6 <123456>
oodathort
Hi all just an up date on my flipkey as i was sent on this trek via your discussions well finished the project today with a toal cost of £30.00 and works a treat
Post #53083 5th Mar 2011 7:01pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
In Nick's case it wouldn't matter as a real 2010 onwards doesn't have a key, just a transponder fob and a start/stop button on the dash. Although there is the emergency key in the side of the fob to open the passenger door 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #53085 5th Mar 2011 7:15pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Please post a photo Smile
Gone - Range Rover Supercharged 2006
Post #53087 5th Mar 2011 7:24pm
dan_uk_1984
Agreed, Photo's or it didn't happen.
Post #53114 5th Mar 2011 9:43pm
^ Yer that!
Post #53121 5th Mar 2011 10:30pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
I did the conversion on my Range,
I bought one kit I talk about few months ago in the last post of this subject :
http://www.fullfatrr.com/forum/topic3946.html
I'll take some pics of my flip key tomorrow, but it looks like this one:
I just moved the transponder from the Range key in the new one, and ask a locksmith to cut the blades I bought
Some pics of the module in the car I installed under the dashboard :
I only used 3 wires, for 12V, openning signal and locking signal. I plugged the Lock wire and unlock wire to the wires used in the driver door to unlock or lock the door with the key. These wires are on the door connector, I'll give you the color tomorrow, because I don't remember the color of it.
When you use the key to unlock the door, it eneble or disable the alarm as well.
The only thinks I still have to do is change lock / unlock option with the key, on my car, using the key only unlock the driver door, I read somewhere that opening the car with the key can unlock all the doors.
And I don't set the option to open the tailgate door yet...
I drive my car every day with this system now for 2 months, and it is more comfortable to keep the key in my pocket
Post #53129 6th Mar 2011 1:03am
oodathort
BMW Diamond Key internals
Post #53132 6th Mar 2011 8:26am
oodathort
BMW Key EBAY £7.00
Flip Key EBAY £14.00
Key Blade cut £8.00
Post #53134 6th Mar 2011 8:29am
So just to clarify in theory any key which fits would work is the transponder was present. the internals are only needed for the remote locking. What is needed for opening the doors with the key?
Once the boring key transponder has been moved to the diamond key and blade cut does it need re programing?
Post #53153 6th Mar 2011 12:27pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
has anyone given any though to replacing the key with a push to start button?
should be feasible i'd have thought?
Post #53155 6th Mar 2011 12:36pm
oodathort
Just to clarify whats needed in changing your old land rover key (bmw) to a flip key
The BMW diamond key has the 3 button in a row layout so get one from ebay as long as it works
Ebay do a flip key housing that will accept the diamond key internal circuit
Get the key on the new flip cut to your key patten
Before doing anything get your diamond key and your land rover key and get into RR with your land rover key put into ignition and turn full on but not start and full off and remove key within 5 sec
Next hold unlock button down on your diamond key and press lock button 3 times within 10 secs all this must be done within 15 secs of removing your land rover key from ignition if it does not work you did not turn ignition on and off fast enough when you get it to work the doors will lock and then unlock to confirm
You now have a diamond key that will lock and unlock your RR but not start it
Next take Knife to diamond key and carefully cut open and remove circuit this will fit straight into the new flip but first remove the old transponder from the circuit card this is where it gets interesting
The BMW key charges the key battery from being inserted in to the ignition if you want this to still happen then you do this
On the diamond key circuit card you will see a 8 legged IC gently cut the legs and remove this is the transponder and its no good to you once done install your transponder into the flip case and hey presto your new key
If you dont want the auto charge then remove the copper coiled part you will see on the diamond circuit card and also peel the battery off its connection and replace with like but non rechargeable install your transponder
Your now done enjoy your new FLIP KEY Porsche Cayenne
RR Sport TD6
Porsche 911sc
AM vanquish
AM Db7
AM DB7
Lotus Esprit V8
Lotus esprit V8
Lotus esprit V8
Lotus esprit 2,2 turbo
lotus espirit 2lt turbo
lotus excel
escort 16 i
capri 2.8i
lotus sunbeem
jenson interceptor
land rover series 1
MGBGT
MG Roadster
Post #53164 6th Mar 2011 1:05pm
Fr_Raf
Nickj wrote:
Bought this key which comes with no branding and like shape/style.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWNX:IT
Will post once arrives.
I tried it, before I bought the system I mentionned above, and it doesn't fit...
Our electronic is bigger than the vauxhall (Opel) shell Confused
Post #53190 6th Mar 2011 5:12pm
oodathort
Hi you need this
http://cgi.ebay.co.uk/Bmw-3-Button-Key-Cas...1e610f58ab
and this
http://cgi.ebay.co.uk/bmw-key-/29053987142...43a5869cbf
Then reprogram as my earlier post
Post #53193 6th Mar 2011 5:30pm
daveo
hi oddathort, where did you get your info from. have you got any pic's and a little bit more in for on cutting te legs on the chip to make it auto charge would be great
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #53199 6th Mar 2011 5:57pm
oodathort
Hi Daveo this is a picture of the diamond key circuit board
The copper wound rectangle is the bit that charges the key battery when inserted in the ignition the 8 legged IC to the left is the transponder you have to remove either for the key to work if you remove the copper wound coil you loose the ability to charge the battery in the fob but you also remove power from the IC if you cut the IC legs you will still be able to charge the fob battery the issue really is that the origional key fob was sealed for life hence the need to charge the battery however your new fob can be opened so the battery can be changed when flat
Thats it
Post #53212 6th Mar 2011 6:44pm
