Home > Technical (L322) > Park Heater fault - help needed... |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Right, I've got my IIDTool and plugged it in and read the HVAC fault code...
31st Oct 2011 10:18am |
Update.
31st Oct 2011 4:19pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Probably being stupid but doesn't the temperature need to be pretty cold before the Fuel Burning Heater fires up? 2012 5.0L S/C
31st Oct 2011 5:15pm |
I did look this up.
31st Oct 2011 5:20pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
i think the outside temperature has to be below a certain level before the FBH kicks in, and not the internal temp... ... - .- -.
31st Oct 2011 5:50pm |
Yes, sorry I wasn't clear. I meant the "Outside Temperature" as displayed on the cabin screen, has to be 16 degrees or less, which it was so I;d expect the heater to start.
31st Oct 2011 5:53pm |
Mine has been working at temps for the last few months when i try it, as even when the temp is above the fans kick in to air cool the cabin or vent to atmosphere, the heat that can build up inside the ffrr
31st Oct 2011 6:16pm |
TBH I don't even know where the heater is. It's buried somewhere in the bowels of the engine bay. The Disco one is easily seen and accessible... Graham
31st Oct 2011 7:21pm |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 |
Possibly the glowplug?
31st Oct 2011 8:18pm |
How do I tell if it's working... especially as I can't find the FBH... Graham
31st Oct 2011 8:43pm |
have you browsed this graham
31st Oct 2011 8:53pm |
Yes, have tried that, defo no gases.
31st Oct 2011 10:43pm |
Been looking at this for a friend with an X5. You can put power to pin 1 on the connector and that will fire up the heater to make sure it's working. They quite often seize or something as they aren't used that often. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
1st Nov 2011 8:07am |
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 |
My FBH on the 2007 FFRR Vogue SE failed last winter during the really bad snow in November.
1st Nov 2011 9:34pm |
