Home > Technical (L405) > Heating query.
LT
Heating query.
This afternoon, whilst driving, I thought I'd try the heated steering wheel and drivers heated seat to see if they worked. Neither did, so I searched around the menus to seek if I'd accidentally pressed something that disabled them. I couldn't find anything obvious under Seats and Climate.
I turned the ignition off for about 5 minutes whilst waiting to pick up a passenger. Drove for 15 minutes and still no heated seats (drivers and front passengers) or heated steering wheel.
Parked up for just over an hour and both seats and wheel are now working again.
Was that a typical LR glitch? Or did I accidentally disable them? If the later, what did I press?
Thanks Thumbs Up
Post #529527 29th Sep 2019 8:53pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
It’s one of two things:
1. Even after two years, I haven’t worked out the exact logic of it, but neither of them seems to come on if the car thinks that they’re not needed! I’ve not had an accidental roasting hot steering wheel since the days of the Disco (thank goodness!), although they’ve always worked when I’ve actually needed them. Could that possibly be it?
2. When the seat heating (or cooling, I can’t remember which it was now!) did genuinely not respond once, it was fixed by a software reflash / update. Did they update the infotainment software before sale? You’ll know if it’s early software as it’ll show a classic red phone box on the home screen.
As long as it works when you first get in and the car’s a bit chilly, then you’re probably okay Thumbs Up
Post #529534 30th Sep 2019 4:25am
Red Merle
Sorry, ignore all of that! Mine’s working under all circumstances this morning!
Post #529545 30th Sep 2019 8:21am
LT
No classic red phone and I have Apple CarPlay. I requested that the software was updated and told it had been done.
The outside temperature hadn’t significantly changed over the period, maybe two degrees C at most.
Post #529550 30th Sep 2019 8:43am
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
If they're intermittently not coming on I'd check the battery... Maybe it was just running low at the time you tried. Steering wheel and heated seats are not related but the battery is a common denominator.
Post #529641 1st Oct 2019 1:35am
LT
Good point. Thanks Thumbs Up
Post #529799 2nd Oct 2019 10:18am
Vogue
What MY is the vehicle ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #529864 2nd Oct 2019 6:32pm
LT
Embarassed Sorry I hadn’t set my profile. It’s an MY17 SDV8 AB
Post #530084 5th Oct 2019 9:41am
Vogue
Don’t think this will apply to yours, but fwiw if your vehicle has the auxiliary stop start battery and you disable it by disconnecting the battery - it also disables the heated seats and heated steering wheel, ditto if the battery is low 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #530090 5th Oct 2019 11:18am
LT
It’s happened again a couple of times. Despite covering over 1,000 miles in the last 8 days, I suspect the battery. Reason being it was sitting at the dealers since April this year, when it was taken as a p/ex and when I bought it 9 days ago.
Post #530106 5th Oct 2019 4:24pm
I think it disables them until battery charge hits a particular level...
Post #530111 5th Oct 2019 6:02pm
LT
Hopefully LRA will replace the battery for me.
They replaced both batteries on my D4 earlier in the year.
Post #530124 5th Oct 2019 7:58pm
LT
Awaiting the arrival of LRA.
Post #530180 6th Oct 2019 2:33pm
LT
Nowt wrong with battery and it’s charging okay. So it’s a bit of a mystery as to why the seats and wheel only seem to work on random occasions.
Post #530193 6th Oct 2019 5:55pm
