![]() | Home > Technical (L405) > Heating query. |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
It’s one of two things:
Sorry, ignore all of that! Mine’s working under all circumstances this morning! |
LT Member Since: 13 Mar 2017 Location: South West Posts: 400 ![]() ![]() ![]() |
No classic red phone and I have Apple CarPlay. I requested that the software was updated and told it had been done.
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 ![]() ![]() |
If they're intermittently not coming on I'd check the battery... Maybe it was just running low at the time you tried. Steering wheel and heated seats are not related but the battery is a common denominator. |
Good point. Thanks |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
What MY is the vehicle ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Don’t think this will apply to yours, but fwiw if your vehicle has the auxiliary stop start battery and you disable it by disconnecting the battery - it also disables the heated seats and heated steering wheel, ditto if the battery is low 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
It’s happened again a couple of times. Despite covering over 1,000 miles in the last 8 days, I suspect the battery. Reason being it was sitting at the dealers since April this year, when it was taken as a p/ex and when I bought it 9 days ago. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
I think it disables them until battery charge hits a particular level... |
Hopefully LRA will replace the battery for me.
Awaiting the arrival of LRA. |
Nowt wrong with battery and it’s charging okay. So it’s a bit of a mystery as to why the seats and wheel only seem to work on random occasions. |
