Home > Technical (L405) > Heating query. |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
It’s one of two things:
30th Sep 2019 4:25am |
Sorry, ignore all of that! Mine’s working under all circumstances this morning! |
30th Sep 2019 8:21am |
LT Member Since: 13 Mar 2017 Location: South West Posts: 396 |
No classic red phone and I have Apple CarPlay. I requested that the software was updated and told it had been done.
30th Sep 2019 8:43am |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
If they're intermittently not coming on I'd check the battery... Maybe it was just running low at the time you tried. Steering wheel and heated seats are not related but the battery is a common denominator. |
1st Oct 2019 1:35am |
Good point. Thanks |
2nd Oct 2019 10:18am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
What MY is the vehicle ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
2nd Oct 2019 6:32pm |
Sorry I hadn’t set my profile. It’s an MY17 SDV8 AB |
5th Oct 2019 9:41am |
Don’t think this will apply to yours, but fwiw if your vehicle has the auxiliary stop start battery and you disable it by disconnecting the battery - it also disables the heated seats and heated steering wheel, ditto if the battery is low 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
5th Oct 2019 11:18am |
It’s happened again a couple of times. Despite covering over 1,000 miles in the last 8 days, I suspect the battery. Reason being it was sitting at the dealers since April this year, when it was taken as a p/ex and when I bought it 9 days ago. |
5th Oct 2019 4:24pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
I think it disables them until battery charge hits a particular level... |
5th Oct 2019 6:02pm |
Hopefully LRA will replace the battery for me.
5th Oct 2019 7:58pm |
Awaiting the arrival of LRA. |
6th Oct 2019 2:33pm |
Nowt wrong with battery and it’s charging okay. So it’s a bit of a mystery as to why the seats and wheel only seem to work on random occasions. |
6th Oct 2019 5:55pm |
