Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Wow Nino thank you! Is there any photo you don’t have?
15th Sep 2019 9:31am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
engine not running, when you give contact, car checks operacion of the turbo actuator. it goes up and down and makes klik / klak sound. when you learn the sound it can be heard from inside car every time you give contact. 2012 TDV8 Black Edition
15th Sep 2019 9:49am |
Ok thank you - but what do you mean ‘contact’?
15th Sep 2019 9:54am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
He means turn the key to the start position ie feed current to the starter. John
15th Sep 2019 10:08am |
like when you checking oil level, Greg. press starter button without pressing the brake pedal. 2012 TDV8 Black Edition
15th Sep 2019 10:11am |
Thanks John & Nino for clarifying.
15th Sep 2019 11:06am |
Also, another question for the team:
15th Sep 2019 11:21am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I think you have the original weaker ones Greg.
15th Sep 2019 12:39pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
Greg,
15th Sep 2019 2:32pm |
Close up picture of my replacement hose/s
15th Sep 2019 2:46pm |
Greg, if there are no cracks in the ruber, no need to change. I am at 230K km and hoses look good. and I like look of the originals better/more to it then just rubber hose/. 2012 TDV8 Black Edition
15th Sep 2019 2:55pm |
Thanks Mike & DrRob, super helpful!
I was replacing serpentine belt Greg, and it is much easier if you take valve out. i did check valve and it was ok. applied some white grees and reinstall. 2012 TDV8 Black Edition
15th Sep 2019 3:05pm |
Greg,
15th Sep 2019 3:22pm |
