Home > Technical (L322) > Repeated squeaks after shutting down [Solved] |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 225 |
I believe that the EGR valves do some post shutdown work out. |
6th Sep 2019 6:56am |
JamieL322TDV8 Member Since: 17 Apr 2019 Location: Stratford Upon Avon Posts: 11 |
And the turbo actuators cycling, helps stop them from seizing up. |
6th Sep 2019 7:01am |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
Interesting. I know I have one EGR that's started to struggle a bit. Maybe thats the one making noise. They are blocked, but not yet mapped out.
6th Sep 2019 8:08am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
The time to worry is when they stop squeaking. Land Rover Addict
6th Sep 2019 11:43am |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 |
Very common, mine does same, as do a lot of others. Might even be a standard feature
6th Sep 2019 11:52am |
Strange. Don't like weird noises under the hood. Always an ominous sign 2007 L322 3.6 TDV8 Stornoway |
6th Sep 2019 12:12pm |
Well, then it's confirmed. It's the EGRs (one, or both) which makes this noise. The graph shows both Turbo actuators and EGRs. The EGR curve coincides with the noise frequency.
6th Sep 2019 4:43pm |
