![]() | Home > Technical (L322) > Repeated squeaks after shutting down [Solved] |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
I believe that the EGR valves do some post shutdown work out. |
JamieL322TDV8 Member Since: 17 Apr 2019 Location: Stratford Upon Avon Posts: 11 ![]() ![]() |
And the turbo actuators cycling, helps stop them from seizing up. |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Interesting. I know I have one EGR that's started to struggle a bit. Maybe thats the one making noise. They are blocked, but not yet mapped out.
The time to worry is when they stop squeaking. Land Rover Addict
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Very common, mine does same, as do a lot of others. Might even be a standard feature |
Strange. Don't like weird noises under the hood. Always an ominous sign 2007 L322 3.6 TDV8 Stornoway |
Well, then it's confirmed. It's the EGRs (one, or both) which makes this noise. The graph shows both Turbo actuators and EGRs. The EGR curve coincides with the noise frequency.
