Home > Technical (L322) > Repeated squeaks after shutting down [Solved]
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
When I step out of the car after stopping (ignition off), I can hear repeated squeaks from the engine bay. The noise is is like a drive belt slip, but repeats as if something is being wound up. The number of squeaks is pretty much constant at 5-7 before stopping (depends how fast I get out of the car).
Any thoughts? 2007 L322 3.6 TDV8 Stornoway
Post #527194 6th Sep 2019 4:56am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I believe that the EGR valves do some post shutdown work out.
Post #527195 6th Sep 2019 6:56am
JamieL322TDV8
And the turbo actuators cycling, helps stop them from seizing up.
Post #527196 6th Sep 2019 7:01am
S.Hafsmo
Interesting. I know I have one EGR that's started to struggle a bit. Maybe thats the one making noise. They are blocked, but not yet mapped out.
The RH turbo actuator I've checked, and it moves freely without any resistance/noise. The LH actuator I've not been able to reach. 2007 L322 3.6 TDV8 Stornoway
Post #527200 6th Sep 2019 8:08am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
The time to worry is when they stop squeaking. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #527226 6th Sep 2019 11:43am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Very common, mine does same, as do a lot of others. Might even be a standard feature Very Happy
https://www.fullfatrr.com/forum/topic10862...t=chirping 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #527228 6th Sep 2019 11:52am
S.Hafsmo
Strange. Don't like weird noises under the hood. Always an ominous sign 2007 L322 3.6 TDV8 Stornoway
Post #527229 6th Sep 2019 12:12pm
S.Hafsmo
Well, then it's confirmed. It's the EGRs (one, or both) which makes this noise. The graph shows both Turbo actuators and EGRs. The EGR curve coincides with the noise frequency.
One can also conclude (1) EGR is the faulty one, as it's got far less movement than the other one (See scale on the left).
Post #527248 6th Sep 2019 4:43pm
