Home > Maintenance & Mods (L322) > td 6 geabox filter advice
deltic
Ireland 2005 Range Rover SE Td6 Bonatti Grey
Hi all, living in rip off Ireland am going to change the gearbox oil rang around 3 land rover dealers for 6 lts of texmatic 7045e g/b oil and a filter, Quoted me 212 euro for the oil, 138 for filter 340 all in, and said the filter is discontinued they can supply a BEARMACH one for 50 Question is i can get the BRITPART filter for 17 land rover for 76. on line. I have sorted the oil elsewhere for 110 has anyone used the britpart or bearmach filters i know the original is best for 76 +vat. th main dealer offered the bearmach so they must be good, what do you think thanks all.
Post #525461 19th Aug 2019 7:55pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Check out the prices for a BMW x5 3.0d filter, Thats what I did and got it much cheaper. The correct spec oil can be found much cheaper, Mine was about 20 pounds for 4 litres, I used about 7. think it was Penrite brand.
https://www.ebay.co.uk/itm/BMW-X5-3-0D-3-0...XQC-tTFg-o 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #525464 19th Aug 2019 8:12pm
Cheapest look a like I could find for 7045E @ £5.80 per litre
https://www.ebay.co.uk/itm/5L-ATF-JATCO-N4...Sw32lYwcl8
can't find a value filter .
Post #525471 19th Aug 2019 8:53pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
think I payed £80 delivered for my kit off ebay , came with oil , filter gasket and new sump bolts
Post #525474 19th Aug 2019 8:57pm
deltic
I have got the oil texamatic 7045 so thats good , its the filter im after the L/R dealer offered the Bearmach one said the L/R were discontinued, so they must be fitting them what do you think, anyone used them with good results cheers
Post #525481 19th Aug 2019 9:52pm
deltic
the gearbox is fine no issues yet. 156k miles original box not bad i should leave it alone
Post #525484 19th Aug 2019 10:00pm
deltic
The price s of parts over here is crazy i paid 18 euro for a rear wishbone nut and bolt. 350 euro for G/B filter and 6 lts oil, it would break the bank if you left it with them to change it.
Post #525485 19th Aug 2019 10:35pm
