![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I might need the ducting Matt! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
LeeKelley Member Since: 04 Nov 2019 Location: Birmingham, AL Posts: 11 ![]() ![]() ![]() |
My back ducting is cracked in the ways that TJ2K's was, cooling works fine, heat setting runs for 10 seconds or so... I've got one quick clarifying question after reading this whole thread:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
worth a try but could go either way Cheers, Greg
Ok, after a pretty thorough repair job to the back ducting and retesting upon reassembly, here’s where I am. Based on what I’ve read here about the seat back being the main source of most issues, I think I’ve got a weird situation:
Sorry to say I think both units have gone.
Noooooooo!
Side note: How do you attach photos? I uploaded a before/after of my back rest ducting fix, but it never showed up in this thread?
You’ll have to check your base ducting.
WOW. This is NOT good news. I wonder how much the entire seat bottom would be (including the black leather), because it's certainly showing the wear. My RR only has 65k miles, but there is the typical cracking on the side from getting in and out. Original owner may have been a bit husky. I'm 205, but try to be careful not to put extra wear on it.
One more question...
You can indeed fit a back unit as I did then see what happens.
carmaniac37 Member Since: 09 Nov 2019 Location: Rochester, NY Posts: 8 ![]() ![]() ![]() |
Gents,
Welcome! Just read above!
I've got an update on my driver seat as well, now that I have the IID Tool...
