![]() | Home > eBay & Bargain Spots > Opie oils |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Limited time offer from Opie Oils ... code GIVE15,
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Castrol Edge Titanium and a Mahle oil filter for my TD6 = £67.50 delivered.
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
This oil ok for 2012 westie ? https://applications.castrol.com/oilselect...2010-2012) |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Oil debates are always fun and full of options and little facts.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
i worked for a mob that had a mob of trucks, all petrol.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
The german site carpartsforless.co.uk - where I got my last year's AF-L oil - is no longer doing the AF-L
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Sorry, you are wrong there. Although new to FFRR's I have recently come from a VW T5 forum. It is a known fact (on there anyway) that using the incorrect oil in early T5's will result in premature camshaft wear & the incorrect oil in the later ones will result in issues with the DPF. Why do you think that a cheapskate outfit like VW produce &/or source so many different oils ? 2003 Range Rover Vogue TD6 |
I did qualify my comment with the correct type and spec... what you are talking about is high zinc additive like ZDDP for high pressure wear points like tap pets, buckets, shims and high pressure fuel pump etc.
A simple yes or no would help ![]() |
Yes, Castrol recommend that oil, it meets the spec and type of use ie suitable for Diesel engines. |
My apologies - I read your post a little too quickly whilst getting GBH of the ear-holes from the domestic authority. 2003 Range Rover Vogue TD6 |
Thank you ur20v. |
No problem to both Brian’s |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 750 ![]() ![]() |
Even if Castrol do recommend their oil I don't get why anyone would choose to NOT use the oil recommended by Landrover.
