Home > eBay & Bargain Spots > Opie oils
Baltic Blue
Opie oils
Limited time offer from Opie Oils ... code GIVE15,
£15 off orders over £75 brings down the cost of a service pack for a 4.4 tdV8 to £77.95, for 10 litres of Shell AF- L, plus filter and free delivery.
That’s my next oil change sorted for £77.95. Thumbs Up Thumbs Up
Post #519384 23rd Jun 2019 8:21am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
never liked shell oil
i have used it on and off over the years, but every time i get into trouble, its back to castrol, problem solved RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #519385 23rd Jun 2019 8:26am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Castrol Edge Titanium and a Mahle oil filter for my TD6 = £67.50 delivered.
Happy days!
Jim
Post #519408 23rd Jun 2019 12:12pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
This oil ok for 2012 westie ? https://applications.castrol.com/oilselect...2010-2012)
Post #520064 29th Jun 2019 8:09pm
ur20v
A Trap
Oil debates are always fun and full of options and little facts.
There are no bad oils out there, just some which are really good. If you change your oil you n time or better still sooner, your oil brand, type of choice and of the correct spec for the application will not be the the point of failure, something else will have gone wrong first!
Post #520095 30th Jun 2019 7:47am
knares
i worked for a mob that had a mob of trucks, all petrol.
they bought a bedford diesel.
they asked the oil company for an oil that was suitable for both petrol and diesel.
the oil company supplied such an oil
the oil company ended up paying the cost of replacing all the petrol engines in the fleet RR 2005 4.4 petrol
Post #520108 30th Jun 2019 8:59am
GGDR
The german site carpartsforless.co.uk - where I got my last year's AF-L oil - is no longer doing the AF-L
Making the Opie deal using Mike's code - the best deal I could find for AF-L
Opie do show a Millers oil compatible with the 4.4 TDV8 but we've learned you must use the AF-L
A bit like using Lifeguard8 on the ZF 8-speed. ZF say use this oil.
Other oil makers say they have compatibles.
Who do you believe?
. Cheers, Greg
Post #520111 30th Jun 2019 9:15am
Brian Considine
Sorry, you are wrong there.
Although new to FFRR's I have recently come from a VW T5 forum.
It is a known fact (on there anyway) that using the incorrect oil in early T5's will result in premature camshaft wear & the incorrect oil in the later ones will result in issues with the DPF.
Why do you think that a cheapskate outfit like VW produce &/or source so many different oils ? 2003 Range Rover Vogue TD6
Post #520115 30th Jun 2019 10:07am
ur20v
A Trap
I did qualify my comment with the correct type and spec... what you are talking about is high zinc additive like ZDDP for high pressure wear points like tap pets, buckets, shims and high pressure fuel pump etc.
Also asking for a generic oil is only asking for trouble.... again right type and spec.
This has nothing to do with brand.
As I said, most comments in an oil thread will come down to opinions and not facts it’s the same as opening Pandoras because x of asking which brand of tools are best, you will get every how has invested saying Makita/Dewalt/Milwaukee/Bosch/Hitachi etc is best.
You pay your money and make your choice.
Post #520123 30th Jun 2019 11:16am
brian1951
A simple yes or no would help Bow down
Post #520125 30th Jun 2019 11:20am
ur20v
A Trap
Yes, Castrol recommend that oil, it meets the spec and type of use ie suitable for Diesel engines.
Post #520130 30th Jun 2019 11:28am
Brian Considine
My apologies - I read your post a little too quickly whilst getting GBH of the ear-holes from the domestic authority. 2003 Range Rover Vogue TD6
Post #520132 30th Jun 2019 11:44am
brian1951
Thank you ur20v.
Post #520142 30th Jun 2019 1:15pm
ur20v
A Trap
No problem to both Brian’s Thumbs Up
Post #520165 30th Jun 2019 5:37pm
cass
Even if Castrol do recommend their oil I don't get why anyone would choose to NOT use the oil recommended by Landrover.
I see all lubricants as being critical to the operation of our cars. I change my oil (Shell) and filter (genuine) twice a year so it costs me about £100 every 10K miles or a penny per mile so even if I was given an "equivalent" oil for free I wouldn't use it just to save this amount which is a drop in the ocean of RR running costs.
I use the same logic with ZF oil for the gearbox, spending £100 for 5 Litres looks expensive for oil every 50K miles but it's cheaper than a gearbox refurb.
Post #520177 30th Jun 2019 6:56pm
